Aug 05, 2017, 01:33 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
Build Log
Sea Vampire ... Sea Plane or Slide off Grass
What I was aiming for was something that would SOG (slide off grass) and hopefully fly from water .. had to be very stable at low speed, needed to be quick and easy to build, and also look reasonably good ...
I liked the way my Vampire flies (https://www.rcgroups.com/forums/show...ge4&perpage=30) so I decided to use this as a base to work from .. I made the wing a bit bigger ... the fuselage square and easier to make ... booms are laminated and easier to make ... I also wanted it to be fairly quiet so a slower motor was needed .. I was worried the the high motor / prop would cause problems but with some upthrust on the motor and some positive incidence on horizontal stab it seems to have done the trick
For the initial run .. I used the Turnigy D2826-10 1400kv brushless motor with a 7 x 4.5 prop, 30 A Plush ESC, 2200 / 3s battery and vector rudder to make it easy to steer on grass or water .. it will probably need some wing floats to keep her from tipping on water
All up weight with 2200 / 3s battery is a tad under 700 grams .... I used 1 sheet of 6mm Depron for the fuselage and other parts and 1 sheet of HK 5mm foam sheet for the wings and cockpit .. I did make the ailerons from 6mm Depron as the HK is a bit on the floppy side on its own
This one really is a very quick and easy build .. I will be adding some wing floats and covering the elevator servo and waiting for a calm day to give her a try from water
Lockey
Sea Vampire Maiden (6 min 30 sec)
A little better quality video
Sea Vampire Maiden HD (6 min 30 sec)
Aug 05, 2017, 03:56 AM
scorchythebear's Avatar
So that's what you've been up to!
That is seriously nifty. I love the vectored rudder
Aug 05, 2017, 06:33 AM
When cows fly!
Very nice!
Aug 05, 2017, 07:10 AM
newcomer's Avatar
vectored rudder? explain.
david
Aug 05, 2017, 07:45 AM
Lockey's Avatar
david
It would be very difficult for a std rudder to work well, if at all .. especially on a sea plane without the rudder being in the water so I decided to try vector thrust for the rudder .. the motor is attached to a swivel plate and so the air from the prop changes the direction of the thrust
Lockey
Aug 05, 2017, 09:01 AM
Retired CAD guy
birdofplay's Avatar
Tony, Very nice innovation !
Good to knkow you're still doing terrific work ;>}
No doubt you've noticed how effective vectored thrust can be.
Plus it eliminates the troubles with a water rudder, big time !
With my recent EDF conversion on the Judi Sea Jet I just put my rudder in the exhaust path and it was WAAY effective. So much so, I had to dial down my rudder a bunch. AND
trim it for exact center too.
On a side note :
Did you get my most recent e-mail ?
Or have you possibly changed your e-mail address ?
I know a guy in Sydney who needs some "local AU, OZ " assistance
Best
BOB
Aug 05, 2017, 09:21 AM
Lockey's Avatar
On a side note :
Best
BOB
Got your email Bob, I'm not ready to do any jobs yet mate (not sure I really want to) but am still trying to get things working good .. I might do some of my own for mates .. wink wink .. eh Duke
Lockey
Aug 05, 2017, 10:08 AM
Careful,.. confident,.. CRASH!
Dukejet's Avatar
Well done Lockey! Thats awesome mate. Did you use the rudder in flight or just on the ground??
Aug 05, 2017, 10:17 AM
Lockey's Avatar
Thanks Duke .. yes mate maybe you can just hear me at the beginning of the flight saying I was using the rudder to turn (about 1 minute to 1 minute 30 .. it wasn't as responsive as I thought it would have been but did turn it, did a good job on the ground though
Lockey
Aug 05, 2017, 03:56 PM
Retired CAD guy
birdofplay's Avatar
Understood.
I hear that intra OZ shipping is miserable too.
Oh well ... ;>}
Hang in there mate
Bob
Aug 05, 2017, 04:09 PM
newcomer's Avatar
Lockey, thanks for the explanation. haven't run across that one before. nice innovation.
david
Aug 06, 2017, 01:54 AM
Looks great can't wait to see how it goes off water.
Sep 11, 2017, 12:58 AM
Lockey's Avatar
Flew her again yesterday ..
Been testing a new FREE video editing software .. run both the videos below together and you will see the difference .. the bottom one I used the zoom feature and I think its much better .. what do you think ? .. software is HitFilm Express
Lockey
SeaVampire2 (10 min 30 sec)
Sea Vampire again (10 min 27 sec)
Build Log Vixen .. Grass Slide or Water Lockey Foamies (Scratchbuilt) 555 Sep 23, 2019 01:21 AM
Question E-Flite or FMS Warbird to fly off of grass field. kid at 55 Electric Warbirds 7 May 21, 2017 02:55 PM
Discussion graupner spinner and prop sliding off of motor shaft danielphantom Electric Plane Talk 3 Mar 22, 2016 10:26 PM
Take off - grass or pavement? Howard2k Beginner Training Area (Aircraft-Electric) 6 Jun 27, 2005 09:15 AM
Sea Vixen or vampire BruceWilkerson Electric Ducted Fan Jet Talk 15 Jun 12, 2003 04:40 PM
