This thread is privately moderated by ckleanth, who may elect to delete unwanted replies.
Aug 04, 2017, 12:53 PM
If it has wings it will fly...
ckleanth's Avatar
New Product
MiniHub+ - S.Port Telemetry Hub for Frsky Radios
I predominantly fly gasoline engine powered planes so it is important to me to use a device that work with the standard Tachometer leads from most gasoline engine ignitions. In addition monitor onboard voltage and engine temperatures.
This is what the new MiniHub+ (for FrSky/Taranis/Horus) does. It works with the standard Tachometer leads from most gasoline engine ignitions . The ignition system has conditioned the signal and it is easily used for the MiniHub+'s RPM header.
The MiniHub+ has also two temperature ports (you will need the FrSky thermistors FrSky TEMS-01) and three voltage inputs (0 to 5v, currently you will need the frsky voltage step down circuit FrSky FBVS to measure up to 5S LiPo battery).
The MiniHub+2/4 (can be used for multi engines) and to use two devices daisy chained together it requires OpenTX 2.1+ due to telemetry sensor ID assignment)
For more information please visit the following page.
https://www.rcgroups.com/forums/show...r-Frsky-Radios
Nov 30, 2017, 08:33 AM
Black_Angel's Avatar
Great info, thanks..
BA
New Product MiniHub+ - S.Port Telemetry Hub for Frsky Radios ckleanth Radios 185 Mar 11, 2020 06:15 AM
Discussion FrSky - We need a Taranis for Surface Radios with OpenTx! Thorvald Radios 21 May 03, 2019 05:04 AM
Discussion FrSky D series arduino DIY hub with naza GPS data to openTX poteroa Radios 65 Jun 19, 2018 02:35 PM
Discussion Motors running oddly? HK multiwiipro 2.0 OpenTx frsky husamwadi Multirotor Drone Electronics 4 Jul 05, 2013 04:16 AM
