This thread is privately moderated by Kearn, who may elect to delete unwanted replies.
Aug 03, 2017, 11:15 PM
Field box
OK I guess I need help on wiring a field box
Aug 05, 2017, 12:53 AM
eagle60's Avatar
What do you mean with field box ? Is that a box for glow motors on which you have a lead battery (usually 6-10 Ah), a power panel, drowers for tools and places for radio and starter ? Or it it a box for electric motors, where you have a lead battery (usually 30-50 Ah) and a charger for lipos?
At the end what do you need to wire up?
Generic questions generic answers.
It could be helpful if you post photos to clarify your needs.
Aug 06, 2017, 07:29 PM
Yes a field box for tools and charging system
Aug 09, 2017, 11:21 AM
eagle60's Avatar
As you say charging system in the field box I presume it is for charging lipos.
Find a diagram with my suggestion for wiring.
Remember : always connect positive with positive and negative with negative, otherwise you will cause a short circuit (dangerous as battery could explode).
Switches are required not to leave socket to external or chargers under tension.
Discussion Field box suggestions? Johnbalz Beginner Training Area (Aircraft-Electric) 10 Aug 18, 2016 01:38 PM
Help! Field box stsguy DIY Electronics 2 Feb 16, 2016 12:10 PM
Discussion Field Box? Tango Juliet The Builders Workshop 16 Feb 15, 2016 06:33 PM
Question LiFe vs Lead Acid for field box xraymiller Batteries and Chargers 10 Jan 12, 2016 01:39 PM
