Aug 04, 2017, 04:35 AM
If it has wings it will fly...
ckleanth's Avatar
Originally Posted by brtman
My first giant scale build, so maybe a dumb question, ....I assume the stud temp sensors with the cm6 size do not exist??
I have the facility to make those temp sensors but theres no point to do so.
I dont like messing about with the spark, and by using one that fits under the spark means that you need to remove the washer that comes with the spark and fit the sensor with integrated washer instead.
If you dont remove the washer from the spark it will be located too high and will change the ignition effectiveness.
If you remove it and accidentally use it in a different engine with no temp sensor on the cm6 spark you may damage the piston.
Conduction of heat through the casing is high and considering the accuracy of the sensors there will be no evident difference as far as I'm concerned as long as you can securely place the sensor to touch the casing (NOT THE FINS)
So no point really...
Aug 04, 2017, 06:10 AM
brtman's Avatar
Thanks for the informative answers guys
Aug 06, 2017, 10:40 AM
ckleanth's Avatar
Anyone got their package yet?
Aug 06, 2017, 11:56 AM
Can it fly? I'll try and see!
ryane67's Avatar
Mine just got through New York, maybe this week
Aug 07, 2017, 02:56 AM
Ersky9x Developer
Mike Blandford's Avatar
Why "only" for openTx. Why won't this work with ersky9x?
Mike.
Aug 07, 2017, 03:09 AM
ckleanth's Avatar
Mike.
not tested it mike. It should but I'm not using ersky9x. Can I send you one to try?
Aug 08, 2017, 07:52 PM
Got mine, which is also the one for Bartman. I think they might have been in the mailbox a couple days....I'm lazy about these things.
Thanks again!
Aug 09, 2017, 01:09 AM
ckleanth's Avatar
Thanks again!
Awsome mate thanks for letting me know. Post pictures and any comments how you get on with it and any improvements to consider
Aug 10, 2017, 05:27 PM
ryane67's Avatar
George, I'm hooking my first one up right now, and I got to wondering.. will this accept 2S lipo through the S-port? I read the instructions and it says not to put more than 5v into the unit anywhere.
I'm runing all my planes on full 2S lipo setups straight into the FrSky RX. .. if these things need a BEC in front of them then they are basically useless to me
Aug 10, 2017, 06:34 PM
brtman's Avatar
Had me spinning too.. I think we can go in through s-port w/ 2s, BUT not with sensors. Sensors and tach only running sig. and ground....... That's how I interpreted the manual
Aug 10, 2017, 06:56 PM
ryane67's Avatar
Yeah I saw both things in the manual and decided 'George is a 3d flyer, he's probably running these on direct 2s' and plugged it in.
Works.
Aug 10, 2017, 07:02 PM
ryane67's Avatar
Now to my observations:
Temp sensor works perfectly, as expected, the same as if I were to plug in the temp/brushless rpm s-port devices I have.
I have a couple of voltage dividers but I don't see myself using them permanently as rxbat in my situation gives me the info I need. I'll hook one up to test it out though.
RPM sensing... it works... but....... it's somehow back-feeding voltage into my ignition module despite only using the signal and ground wire on the extension. This plane has an EME35, so their ignition module is an Rcexl piece that has the RPM output so I'm plugged into that with my 2-wire extension. As soon as I connect the minihub to the rpm output, the LED for my ignition kill lights up. not good
Aug 10, 2017, 07:09 PM
brtman's Avatar
no, not good. Keep us posted
Aug 10, 2017, 07:41 PM
ryane67's Avatar
it appears that the Rcexl opto kill switch works by switching the ground leg from the ignition box, not the positive.
as soon as I provide a gnd by connecting the minihub to the box, the electrons flow through this new ground instead of the one blocked by the optical switch.
Aug 10, 2017, 08:44 PM
brtman's Avatar
I'm not using opto switch................
Discussion FrSky - We need a Taranis for Surface Radios with OpenTx! Thorvald Radios 20 Aug 04, 2018 12:05 PM
Discussion FrSky D series arduino DIY hub with naza GPS data to openTX poteroa Radios 65 Jun 19, 2018 02:35 PM
Help! Opentx Turnigy 9x Frsky telemetry Ramdg Radios 0 Oct 24, 2015 10:38 AM
Discussion Motors running oddly? HK multiwiipro 2.0 OpenTx frsky husamwadi Multirotor Drone Electronics 4 Jul 05, 2013 04:16 AM
