Sonicmodell F1 Wing 833mm Super High Speed FPV EPP Racing Wing Kit/PNP - RC Groups
Aug 03, 2017, 05:15 AM
New Product
Sonicmodell F1 Wing 833mm Kit: https://www.banggood.com/Sonicmodell-F1-Wing-833mm-Super-High-Speed-FPV-EPP-Racing-Wing-RC-Airplane-KIT-p-1181349.html
Sonicmodell F1 Wing 833mm PNP: https://www.banggood.com/Sonicmodell-F1-Wing-833mm-Wingspan-Super-High-Speed-FPV-EPP-Racing-Wing-RC-Airplane-PNP-p-1181348.html
Sonicmodell have released quite an interesting looking wing with seemingly promising features and characteristics. I'm mostly curious as to the wing connecting mechanism employed here.
Overview
This Super High Speed F1 Wing is designed for extraordinary high speed FPV experience. It’s symmetric airfoil driven by 4S power system provide very strong and smooth thrust, meanwhile, we use High Density but Solid EPP foam to ensure the whole air-frame super rigid and crash resistance, the built-in plastic hinge inside the aileron provide very accurate reaction from radio control for combat fly, this wing is compact and portable for out-door FPV flying because of the detachable main wing. You can install your FPV gear and 4S battery inside the spacious hatch with “NACA” air-inlet and outlet. The digital servo’s arm were very well protected by the aerodynamic plastic cover, the bottom of the fuselage were also protected by plastic parts as well. We believe this robust Formula 1 Wing will exhilarate you greatly from the normal FPV flying.
Description:
Brand Name: SONICMODELL
Item Name: F1 Wing
Wingspan: 833mm(33")
Length: 420mm(16.53")
Flying speed: 20km/h - 190+km/h
Recommend Parts (Not included/included depending on version):
Motor: 2216 2000kv (Shaft Diameter: 5mm) Click here
ESC: 40A 3-4S (XT60 connector) Click here
Servo: 2pcs* 9g digital servo Click here
Propeller: 6x4.5 Click here
Recommended Battery: 14.8V 1800-2200mAh 30C
Features:
* High Density EPP molded wing and fuselage, super hard and rigid, plus pre-built in carbon fiber spar, durable and flexible
* Detachable wing structure, compact size, portable and easy to take for out door FPV fly.
* Built-in plastic hinge inside the aileron provide very accurate reaction from radio control
* Symmetric airfoil driven by 4S power system provide very strong and smooth thrust.
* “No-glue” required assembly, open box and fly in few seconds
* With plastic aerodynamic cover to protect the digital servo arm
* Spacious equipment bay for more FPV gear.
* With plastic cover to protect the fuselage bottom from landing scratch
* With bump for “CG” mark under the main wing.
* With "NACA" Air inlet and outlet for FPV gear cooling
Package Included:
1X F1 Wing KIT unassembled but including all foam parts, plastic parts, hardware, plywood, carbon fiber strip and tube. (FPV Camera / Battery / radio controller are not included)
Aug 03, 2017, 02:22 PM
It seems like there's a new FPV wing coming out every day.
I'd like to build an iNav enabled wing sometimes in the next few months, and right now this one seems to be taking the lead.
Aug 04, 2017, 02:38 AM
Leo
Very nice
Aug 04, 2017, 04:02 AM
Yana547's Avatar
I will try AR Wing first...still otw
Aug 04, 2017, 10:05 AM
Yeah I was looking at the AR wing as well as the s800 and the ZOHD Orbit, or the Z-84, but this looks like it hits all the things I want exactly right. A fast wing that can easily hold a big battery and a flight controller.
Sep 07, 2017, 03:31 PM
Racer.Lt Owner
Frimen's Avatar
It's great wing! But servos must be metal for sure!
SonicModell F1 And AR Wing PNP KIT - maiden (16 min 52 sec)
Sep 21, 2017, 04:32 PM
I found an unboxing review.
Looks like very high build quality.
I'm interested to see if the battery bay is big enough to fit a flight controller.
"CRAZY DENSE FOAM" 📦 Unboxing the Sonicmodell F1 Wing 33" FPV Racing Wing (34 min 37 sec)
Sep 22, 2017, 02:36 AM
Reap the wild wind
headlessagain's Avatar
Matt plans to maiden his F1 today. Knowing him it will be a quick los followed by fpv. On 4s of course.
Worth subbing to his channel as he's a wing and fpv nut and tends to buy most of the new products for review & destruction testing
Andy
Sep 22, 2017, 11:59 AM
smoothvirus's Avatar
Andy
"Rag the Nuts Off" +100mph SonicModell F1 FPV RaceWing (3 min 44 sec)
Oct 08, 2017, 12:11 AM
Sonic Model F1 Racing Wing (5 min 28 sec)
Oct 08, 2017, 08:32 PM
VLOG #4 - Unboxing the Sonicmodell F1 Wing (8 min 50 sec)
Oct 09, 2017, 07:48 PM
Flight Review of Sonic Model F1 Racing Wing (10 min 18 sec)
Oct 12, 2017, 01:19 PM
cflchurch's Avatar
Johnny mentioned it had a little wag at speed, do you think adding adding winglets toward the middle would help reduce any tail wag?
New Product Spirit 600mm Wingspan EPP FPV Racer Flying Wing RC Airplane KIT BG Tobey Flying Wings 136 May 10, 2018 06:52 AM
Discussion Realacc Black Spirit 500mm Wingspan EPP FPV Racer Flying Wing RC Airplane KIT scousethief Banggood.com 3 Jul 24, 2017 03:10 PM
New Product Rainbow EPP 970mm Wingspan Flying Wing Racer RC Airplane KIT D Gains Flying Wings 1 Jun 17, 2017 11:41 AM
New Product DW HOBBY Rainbow Ⅱ Flying Wing 1000mm Wingspan EPP FPV RC Airplane KIT - $28 lmpuIse Flying Wings 5 Dec 10, 2016 12:06 AM
New Product Sonicmodell Mako Flying Wing 1213mm Wingspan FPV RC Airplane PNP Whitehouse FPV Talk 0 Feb 10, 2015 07:01 PM
