Jun 09, 2018, 05:02 AM
nickboul's Avatar
Originally Posted by nickboul
Do q6 lite get updates?
Any one?
Will there be an update that will enable to Charge a lion battery at 4,2 per cell?
Jun 09, 2018, 07:59 AM
Any one?
Can't you use the Lipo setting?
Jun 09, 2018, 08:02 AM
nickboul's Avatar
Is it safe?
Jun 09, 2018, 08:24 AM
Lipo will charge to 4.2V per cell.
Jun 12, 2018, 02:00 PM
older Firmware can not solve "abnormal battery connection"
Originally Posted by ruckelg
Hi,
does anybody has got the Firmware Q6_plus_V2.1.0.17 or Q6_plus_V2.1.0.18.
I thing that this older Versions does not have the software test for the abnormal battery connection.
Hi,
just tested the V2.1.0.17 but the "abnormal battery connection" error still occured.
So the firmware 2.1.0.17 already had the function to test the voltage difference of XT60 vs. balancer.
Thanks for your help
Jun 12, 2018, 02:03 PM
I would see if ISDT will replace it. If not maybe you can take it apart and see if you can fix it. There are a couple of fuses inside that can blow. You could also try the calibration routine. There is a separate calibrate for the XT60 reading and the balance port readings. Maybe re-calibrating it might do the trick.
Aug 25, 2018, 06:57 AM
Has anyone older firmware for T6 Lite ?
I cant change current after update -
ISDT T6 Lite (v1.0.0.18) - problem with current after update !!! (1 min 16 sec)
Aug 28, 2018, 01:26 AM
mihah's Avatar
Hello,
i am asking this question for a friend of mine. ISDT T8 doesn't memorize the low voltage limit and power limit for input power after power cycle. FW 1.0.0.27.
Does anyone else have this issue? Thanks for your replies in advance.
Apr 06, 2020, 10:52 AM
Aerospace enthusiast
DRONE_NERD's Avatar
Hi,
Which App/software I'll need to update FW of my T8 and BG-8S?
I found only the FW, but no the App (I'm using win 10).
Thanks!
Apr 07, 2020, 06:24 PM
Do you have the ISDT firmware adapter? It's a USB device with a headphone jack on it. The software to update the firmware is included with the firmware download off ISDT's website.
Apr 07, 2020, 07:39 PM
DRONE_NERD's Avatar
Yes, I've the USB/Adapter cable.
I'll check the ISDT website.
Last year that website was off for several times... I did download T8 FW, but haven't any software into zip file.
Thanks for your time.
Discussion ISDT Smart Charger NEW firmware update ISDT Batteries and Chargers 53 Oct 04, 2019 06:58 AM
Mini-HowTo ISDT SC-620 Smartcharger only Chinese problem and a trick for update firmware mrlocchoc Batteries and Chargers 8 Sep 29, 2017 03:29 AM
Discussion Flash firmware for internal modules for Taranis X9D Plus FIRMWARE UPDATE ERROR baptist FrSky 2 Jan 25, 2016 04:58 AM
Mini-HowTo Update Firmware for Devo TX - Import/Export Devo TX Models - Update Devo RX Firmware Tom Z Micro Helis 22 Jun 28, 2015 12:20 AM
Help! Firmware update error with OSD pro ONLY Data Logger and Gardian firmware update works whosthebaddest Eagle Tree Systems 10 Mar 17, 2012 05:26 AM
