Sep 05, 2017, 09:20 PM
taildragger21's Avatar
Originally Posted by Matze 42
Can you give me the Flap Setup for take of ? ..
my Gear look's rocksolit..no loose in it but I'll take extra care to it
I've performed takeoffs both without flaps and 10 degrees. We do have 800 feet of pavement however
Sep 06, 2017, 03:55 AM
Originally Posted by taildragger21
The latest gear fixes those issues but they have a bit of slop in the mechanism. Hopefully robart will have their optional gear ready soon.
Did you also opt to not use the gear doors? I left mine off.
Hello,
Gear doors are off in this one. I will take off mine too.
Reason is : they installed the servo connection of the gear doors to back side/tail side so door servos are pulling the door on and of from back side. No matter how much you adjust the servos to pull up and close the doors, there always remains a small gap on front side which can cause problems during flight.
Well you can make an extra assembly like putting a weak-ish magnet on front side so when servo pulls up from back, magnet will snap the front side... But no gear doors at the moment, at least until we are sure all issues are fixed with the model.
Sep 06, 2017, 03:59 AM
Flap throws are 85 mm. on manual.
On this flight they are somewhere between half flap and full flap.
I asked my friend but he doesn't remember exactly...
Nov 02, 2017, 02:18 PM
Hello all,
Any more news from the few of you who have built this plane?
Mine is arrived but need to find some time to start building ;-)
Best regards !
JF
Mar 14, 2019, 06:44 PM
G4
I have a G4,
Where did you measure the cg from ,the wing where the slope is?
or the area where the wing has the straight line?
Also are the throws correct.
Thank you very much.
James smith
Mar 20, 2019, 07:52 AM
Could someone say what size the wheels are? Jist wondering for another project, pc21..
Dec 10, 2019, 07:55 PM
artchristic's Avatar
Hi;
Thinking of getting this kit also but kind of worried with the main gear breaking all the time. Any new news from Top RC or Robart for the gear redesign upgrade??
Dec 14, 2019, 08:42 AM
I have on coming next week can't wait to see it.
Frank
Dec 15, 2019, 02:47 AM
Hello
They changed the gear design. You can find a video on YouTube. I have mince since a while and no problem
Best regards
JF
Jul 16, 2020, 08:02 AM
kimhey's Avatar
If anyone can cofirm the CG stated in the manual (seems a bit nose heavy) or user experience, I would be very thankful
Jul 17, 2020, 02:56 AM
kimhey's Avatar
Maiden done. I set the CG at 220mm (10 behind factory), and it was perfect.
Jul 24, 2020, 06:33 AM
RC pilot by soul
TopRC Model G4 Galeb - flight #2 (6 min 18 sec)
They fly amazingly well !
Oct 30, 2021, 07:26 AM
Did you messure cg from where the wing meet the fuse? I need 1200gram in the nose to get it to 220mm
Oct 31, 2021, 04:33 AM
RC pilot by soul
you are way off. the galeb in the video is balanced without lead.
Mar 02, 2022, 02:52 AM
Eventually where did you put your final CG? Coz ure right with my p120 i need almost 1200gms to get the cg on 220mm, or should be increase the cg point to 260mm?
Discussion Top Model Grafas MAXi 3.5E discussion and build thread gquiring Electric Sailplanes 242 Mar 26, 2024 04:03 AM
Discussion Top Model Samsara build and discussion thread gquiring Electric Sailplanes 171 May 25, 2021 04:03 PM
Build Log Top Flite Cessna Skylane Kit Build Thread stevenewald Giant Scale Airplanes 4 Jun 12, 2017 02:05 PM
Discussion Top Flite Peacemaker Control Line to RC Conversion - Build thread Rightseater Glow to Electric Conversions 19 Sep 03, 2012 10:31 PM
Discussion RC Jet Turbine Exhaust Tube Build Thread BJ64 Jet Turbines 1 Jul 30, 2010 10:17 AM
