Aug 01, 2017, 02:00 AM
looking up, down under
scruffy1's Avatar
Build Log
"the canardly"
i got most of the work done on my "cutie", and then decided to take a breather to consider the hinge detail and other stuff
having been recently impressed by a build from "GrandadIsAnOldMan" on youtube, i felt the urge to take out one of the stash of capacitor powered paper dart kits i got some time ago from hobbyking, and make the depron hot rod equivalent of a paper dart
the a4 paper for the dart is 80gsm, meaning an a4 sheet is in at 5 grams, which was the target for the airframe; the motor and capacitor are in at 6.5 grams, making the designed paper dart all up weight at 11.5 grams
the finished plane weighs is at 11.9 - 12 grams all up, but has a far bigger wing area
the layout of the motor and capacitor made the most practical layout a canard, and i plagiarised plans from both the candice (a ray malmstrom rubber design from aeromodeller april '72 that i made back in the day), and the parlor pusher from model airplane news january 1959 lifted from outerzone
it all went together in an afternoon
the initial glides were crap, diving into the proverbial tall grass even with increased nose winglet incidence - hence the name, because it appeared that it "can 'ardly" fly
but the application of some reflex camber using a metal edge to crease some elevons, and then re-attaching the wing fins to hold in the "up" was immediately successful - it glides very flat in a slow right hand turn
the motor rotates clockwise from the rear, so torque should straighten out the climb some; there is maybe 3º downthrust built in to the motor mount by default as mounted, which again is probably appropriate for the design - if it turns out wrong, i can easily add more downthrust by shimming under the blenderm.... if it's too much as is, i can slot the rear, and wedge it up instead
anyway, pics below, with further info on the construction
if there's adequate power for good flights, i could envisage an sr-71 blackbird and the starship enterprise as natural evolutions
Aug 03, 2017, 07:58 AM
scruffy1's Avatar
well, that works
carnardly (0 min 49 sec)
Aug 03, 2017, 10:40 AM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
Everything comes full circle ( almost) , just like the RC planes of the 60’s where you pushed a button once for left, two for right , and if you got it back to the field in one piece it was a Great day …
It is however , very CUTE !!!
What about a bigger one with a real radio, and Throttle ?
Latest blog entry: Lost plans
Aug 03, 2017, 03:14 PM
skumgummi dave
+1 What gpw said. A 4x version of that would be really cool. How about it scruffy1.? Can we have a plan?
Dave-
Aug 03, 2017, 08:26 PM
scruffy1's Avatar
thanks for the kind words - i expected that it would fly with the powerplant after i got the glide sorted out, but the thrust and duration expectations were somewhat of a mystery
as for plans... there weren't any when i made it, but as requested i will take the time to measure it up and post a rudimentary set with dimensions at the size it is, and you are welcome to scale it to whatever you desire
the wing is a simple undercambered piece of 2mm depron, as baked here
a bigger one would have adequate space to hide the rx / servos and esc in the rear wing "hump", and by deepening the rear fuselage aerodynamically between the under fins and making the fins a bit deeper (or extend them above the wing) if i was to try it, with an outrunner mounted on the rear thickness thus created
streamline the fore wing mount for your lipo, which would make it balance correctly, and away it goes
edit :
plan now uploaded - the graph paper is 5 mm square grid , but all useful dimensions are clearly marked - if you use those as inches you'll end up with a 30" version
forgot to add, the dihedral of the main wing is 4 (units) at each tip, while the fore plane is 2 (units) at each tip, or more simply 4 on one side with the other flat on the board
released under copyleft, so share it round if you want, under that arrangement
Aug 04, 2017, 10:16 AM
skumgummi dave
scruffy1:
Good on you mate! Thanks for the plan. It's superb...
Dave-
Aug 04, 2017, 08:57 PM
scruffy1's Avatar
if you get up and running, please paste a link in this thread to any build log
for r/c, given the relative weight of motor and other requisite components, i'd suggest you leave the opportunity to make the nose longer, and trim it to an appropriate length for the battery you choose, so that there's no need for ballast - the nose moment is likely a bit short for balance unless you cluster the radio stuff ahead of the wing somehow, which would detract from the streamline
have fun
Aug 08, 2017, 09:28 AM
I Look, Listen, and Learn
Timbo383's Avatar
Damit, another one for me to try to build.... That is one neat looking plane scruffy.
Aug 08, 2017, 01:53 PM
I meant to do that. Honest!
JamesPotts's Avatar
Very cool!!! I had no idea such a power system was readily available.
Sep 26, 2017, 02:16 PM
Slow Flight
i have one of this units waiting for a plane ....this the one i was looking for.
Any advice how to make it fly in circles? and not straight line?
Alex
Sep 26, 2017, 07:32 PM
scruffy1's Avatar
no idea, actually
mine flies as per the video, which may be due to motor torque
the front winglet is slightly lower on the right tip, as per the initial photo shoot
apart from the poor initial glide (solved with some reflex on the main plane), it just flew without adjustment, although the climb is rather straight, but the glide as power runs out is gentle right circles as per the video
dunno if these help, but here ya go :
canardly #2 (0 min 46 sec)
canardly #3 (0 min 35 sec)
Sep 27, 2017, 12:16 PM
Slow Flight
scruffy1,
Again, it looks incredible and flies very good.
I can wait to make one, i hope i can use a 2mm material from a foam plate.
thanks for the additional videos.!!
Sep 27, 2017, 07:41 PM
scruffy1's Avatar
there was a bit of breeze on the day, so the flight pattern hasn't been fully trimmed
it could probably do with a tiny bit less incidence on the foreplane, after i added the reflex as a better way to cure the dive it showed gliding
the video shows it gently stalls when gliding, but most of the powered flight is well behaved so i'll consider any changes after some testing flights here if the winds finally dissipate some, and report back in the thread
Sep 28, 2017, 06:47 AM
Slow Flight
How did you get such a clean cuts? I am using dollar store ( 4mm) board foam with a X-acto knife and new #111 blade and i got real bad edges. Sorry about the question i am learning.
Sep 28, 2017, 07:28 AM
scruffy1's Avatar
we don't have dollar foam here, but i have discovered that depron will sometimes tear despite a sharp #11 blade
hold the blade so it is about 45 degrees to vertical as you cut, and if the material is thick, don't be intent on cutting all the way through on a single pass
also, the tear will usually be at the bottom surface of the sheet, so you might consider tring to "complete" the cut from the other side by turning the sheet over before you go all the way through - possible to accomplish by using the partial cut as a guide, and pushing the blade at 45 degrees, so it cuts "down" on the top surface if that makes sense
if the edge isn't perfect, you can sand it, but with very fine paper and in one direction only, not back and forth
Build Log Basalt, 1m Span Canard-Twin, with plans. TeamWang Foamies (Scratchbuilt) 18 Oct 29, 2015 10:46 AM
Discussion Elevon-canard mixing? georgy Foamies (Scratchbuilt) 7 Oct 10, 2015 07:56 PM
Video Canard Addict's Giant Canard Glider rcflyer11 Electric Plane Talk 7 May 01, 2010 09:21 PM
Discussion Of canards and pusher props... (new Barracuda canard prototype) Rusty-Gunn Foamies (Scratchbuilt) 30 Mar 02, 2008 11:23 AM
