Auto g2 prerotator not spinning up - RC Groups
Jul 30, 2017, 10:22 PM
Cantaloupeman's Avatar
Question
I got this plane for christ.as and haven't set it up until now only to realize that the prerotator won't spin up. I have the rotor blade off which I assume has nothing to do with it, and another thing worth mentioning is I have a airtronics sd-5g and I am plugging in the prerotator to ch5 which is "gear" in the radios manual. Could my radio just not accept anything other than gear for that slot? I also have the dean connector plugged in so it isn't that. Maybe the type of battery is wrong and can't output power from the dean connector? Plz help. I'm really hoping I don't have to call customer support. Thanks!
Aug 09, 2017, 02:13 PM
old nitroman's Avatar
on mine the prerotator is pluged in to the balance plug . and has it own esc
Aug 11, 2017, 12:00 AM
Mine as well but it still doesn't spin up I think it may be broken
Aug 11, 2017, 03:22 AM
by pass the esc , put battery wires to the motor see if it run use the correct voltage, remember that motor has brushes, then check the out put of the esc
Nov 10, 2017, 05:58 PM
Sorry to dig up this old thread but I am borrowing a spektrum TX and the rotor spins up when I plug the prerotator into aux 1 but it doesn't spin up when I plug it into ch 5 on my airtronics. I have 5 channels on my airtronics TX and rx. Ch 5 is labelled as "gear" on the rx. Why could this be happening?
Nov 30, 2017, 03:25 PM
try servo in that channel make sure it works, is the airtronics older. may not be compatable , airtronics had a different servo wiring, not the same as spectrum.
Nov 30, 2017, 04:11 PM
but you get it to work, know how servo color code, find servo neg, postitive, signal wire are been so long I do not remember airtronics wires are 1,2,3, if I remember right. Cliff
Discussion Is the Auto-g2 a good auto gyro to start on? Cantaloupeman Auto Gyros 24 Jul 03, 2017 12:14 AM
Discussion Auto up throttle problem, not on airmode, help! Lateralship Beginner Multirotor Drones 7 Feb 11, 2017 07:26 PM
Discussion Modification of Durafly Auto G-2 prerotator orvie6 Auto Gyros 4 Sep 26, 2016 09:18 PM
Discussion Help! Motors spin up using Baseflight but not using TX cliffhanger777 Multirotor Drone Electronics 4 Jan 18, 2016 03:47 AM
Help! Motor not spin up after upgrade to Cleanflight 1.10 lcc014 Multirotor Drone Electronics 5 Oct 16, 2015 01:42 PM
