I think i solved the puzzle with the proprietary servo. The servo was a major problem when you wanted to upgrade to hobby grade ESC and receiver.
Well to convert the servo to standard 3pin i sacrificed the control board of a small tower pro SG90 servo. It was a bit of a hassle to match up the signal cables cause they don't color match but i was lucky. Video is uploading here :
Please check the video and let me know if this is the full motion of the servo. |
i haven't put it in the car yet, i just figure it out like 15min ago.
I wanted confirmation that the range of motion is OK before i take the car apart |
I installed it on the car and it seems to work OK
uploading video here:
The steering needs trimming because its not straight but its just a test. What do you guys think ? |
The car is ready lets summarize the upgrades so far:
* Axle wideners * Brushed ESC ( in the battery compartment ) * FlySky Receiver * Coverted original steering to 3pin * Motor Heatsink * 2s lipo 2000 mah * Remo shocks to lower the car and make it not bounce so much Upgrades to come ( waiting for hardware ) * HBX wheels ( only have 1 pair now ) * Lights * Oil shocks * FPV * Maybe a horn ( if i can figure out how to make one ) The only problem i had with the car is that it was very hard to line up the steering properly and it required "mechanical" trim if i can call it that from the car also needed trim and subtrim from the controller and also raised the limits of the steering channel to 120%. I am happy with the upgrades so far and the car looks as "clean" as possible. |
I think your are going to love this, corona servo with the original gear shaped servo horn.
The steering went from lame to awesome. This is the kind of servo i use of my Feiyue so if it work perfectly on that car on the 9120 its overkill |
Update:
* Made Velcro straps, and modified the battery cover so i can fit the straps. * The servo cover no longer fits, so i cut the front part of the cover because it was a structural part securing the front of the car to the chassis. * Pour hot glue over my DIY mount to make it stronger. * I also cut off the power switch of the ESC because when the car moving, sometime the switch would trigger cutting power to the car. * Steering travel now is way to much had to tune it down to about 60% * Also tuned the end points of forward to 110% and reverse to 70% * Added some expo to the throttle channel to make acceleration smooth so i don't grind the gears I believe that's it for now |
Next mod completed lights:
* Led lights installed in the buckets on the roof * No controller is needed * Lights are connected to the esc plugs going to the motor and the light work only when you press the throttle and the intesity of the light vary depending on the amount of throttle. This is a very easy little trick from the old days when there were no led controller and you only had a 2 channel radio anyways. This car is not that fast and it does't roll over easily since its lowered and more wide now so, hopefully the wiring on the roof will stay in place. Usually i take off the roof light buckets cause on faster better car there is no chance that the lights will stay in place but the 9120 hasn't much to show and it needs a little "bling" to impress lol |
Filter on the motor to keep dust and debris out
Here is a test run of the car with all the mods i have done so far:
Latest blog entry: For the love of the hobby!
lol
Thread Tools | |
Similar Threads | |||||
New Product | Feiyue FY-C10 1/12 2.4G Amphibious Vehicle High Speed Off-Road RC Car 35km/h | abinge | Off-road Cars | 21 | Mar 30, 2018 02:13 PM |
New Product | XLH 9120 1/12 2.4G 38km/h Desert Off-Road RC Car Racing Truck Car Best Gift For Grow | BG Tobey | Off-road Cars | 76 | Oct 26, 2017 05:52 AM |
New Product | Feiyue FY03 Eagle-3 1/12 2.4G 4WD Desert Off-Road Truck RC Car | Kenxiaofei | Car Talk | 4 | Dec 31, 2016 06:08 AM |
Discussion | FEIYUE - 02 1 : 12 2.4G Full Scale SUV 4WD RC Off-road Racing Car | S3MKi | Off-road Cars | 1 | Feb 17, 2016 09:40 PM |
