http://support.gitup.com/solution/ar...f1-user-manual The 90 degree version will be 2 to 3 weeks later than 160 degree version. |
What's the weight of the camera?
Cool, there're already plenty of those around so not hard to find
![]() *edit: just had a look thru the manual, and I have some suggestions: - some short(er) settings for video timelapse would be nice, like 0.2s and 0.5s; these would be great for 'roadmovies' (1s is already too 'fast' for that). - "Calib (Calibration)" is an unclear name for distortion removal which would be a simpler and clearer name imo. |
Received my sample. And for now it looks good. Still a few things to fix in firmware, but my testing so far says it is pretty good. Did not try the lens-correction yet. Very fast switches between clouded skies and grass exposure.
The lens sticking out almost as far as the sides also worries me a bit. At least it is all glass lens. I got a few improvement ideas, but there is no show stoppers. Just got latest firmware today, so no detailed comments yet. I do consider designing a 3D printed hood for better lens-protection in lower resolution. Print it in flex-PLA which I have plenty of from the HobbyKing sale. With 160 degrees FoV there is not much room for anything in full res. Build quality is nice. OLED display a bit difficult to read in full sunlight. But not impossible. And not too bright in low light conditions. Did not test the GitUp app yet, used a generic Ambarella App to see the WiFi streams. |
One good thing is, that in loop mode we can have down to 1 minute segments. Some people hate short segments, but to me it is great. Means less video lost in case of crash - Plan to use it on planes, but weather is getting bad here.
Maybe I need to build my HobbyKing SkyRay / RMRC Mako wing, as it has a nice big clear FPV dome. Guess it could be a nice rainy days FPV platform. My sample came with the FPV cable, not the TV-out cable. But my Samsung plays the videos directly using USB cable without any issues. Manual does not mention PWM. Will make some tests to see what the cut-off level is (1500us?). If a high will keep taking photos/videos, or if the crossing = pressing button once. What behaviour do we really want ? Personally I would like to be able to record video at whatever resolution, and trigger i simultaneous JPEG using PWM. I will likely not turn video recording on/off on most flights. Maybe on long distance FPV when I get to that. |
Think SJCam resellers on AliExpress wanted $20 for battery doors, so of course these are available in a few different user created designs on thingiverse. Creating a lense hood for slip on should be easy. Lens assembly is long enough that it might stick, especially if printed in flex with tight tolerance. The petal flower style lenshood for my EF-S 10-22mm does not stick out much, but it makes the difference in touching or not touching the lense / filter.. |
Did not know my git2 had PWM control.
We have the Ambarella A12 here. And you can set it to video+jpeg at intervals. So simultaneous video + photo is possible. Not sure about compression. If you really just get a video keyframe ? Or if it is a jpeg with less compression. It is pouring down here for the next week. But there are many things I can test. And I am slowly collecting things for feedback. Like everything else the software can be improved. Missing the zoom option on EIS. Should be possible to change For more zoom. |
I think you will just get a video frame saved as a jpg for photo or interval timer while recording, extracting a video frame from the video may give better quality. Some of the more recent chips can manage a full resolution photo while recording though, so it may be with us in the next generation. |
Thread Tools | |
Similar Threads | |||||
New Product | Upcoming GitUp Cameras - GitUp F1 & GitUp G3 Duo | D Gains | Aerial Photography | 99 | Dec 13, 2017 07:56 PM |
New Product | GitUp GIT2 GIT1 FPV HD camera - lightweight LCD champion | tvdrone | Multirotor Drone Talk | 6 | May 15, 2017 07:02 PM |
Question | Does latency improve with cheap fpv cameras over gitup git2? | babipsylon | FPV Equipment | 6 | Sep 17, 2016 09:22 AM |
Discussion | Which Action Camera is the best for Aerial Video? Gitup Git1 or Xioami Yi or what? | RealRCGeek101 | Mini Multirotor Drones | 2 | Jan 22, 2016 07:36 PM |
Discussion | Which Action Camera for FPV is the best? Gitup Git1 or Xioami Yi or what? | RealRCGeek101 | FPV Talk | 0 | Sep 20, 2015 11:07 AM |
