lift pressure - RC Groups
Jul 27, 2017, 10:13 PM
lift pressure
I'm building a bagged hovercraft that measures 48"x30". I will be using 2-400w counter rotating motors 5x4.5 3 blade props to fill the bag and create the lift. Lift air will be what exits 6, 1" diameter holes from the air bag. The lift motors are mounted on either side and approximately 1/3 of the way from the front. The estimated
Will I get enough air flow to create enough lift or will I need more air flow from the bag?
Jul 28, 2017, 12:38 PM
Rapidly aging user
raw89's Avatar
Total flow needed depends on weight, shape, ducting, etc. Start w/ fewer or smaller holes and keep increasing them until the bag pressure is just slightly higher than the bottom lift pressure (the bag will get softer & the bottom skirt gap will increase).....good luck....send pictures....
Jul 28, 2017, 01:38 PM
The bag is going to be rectangular, the lift motors will be mounted in vertical ducts that with minimal clearance for the props. I'm going to try getting enough lift to handle a total weight around 20lbs.
Jul 28, 2017, 08:17 PM
Rapidly aging user
raw89's Avatar
20 Lbs???? I'd say that's about 10 times what's feasible w/ your hardware......
Jul 29, 2017, 09:02 AM
I'm gonna test it before I get to far into it. If it doesn't work I will make changes based on how it performs. Either add another set of lift motors or go a completely different direction.
Discussion Starting my Heavy lift hexacopter build. 200lbs of lift. irishluck Scratchbuilt Multirotor Drones 24 Sep 27, 2016 08:40 AM
Help! Quad won't lift off/lifts to one side AnabolicHippo Beginner Multirotor Drones 7 Mar 09, 2016 12:59 AM
Discussion relative pressure zones around symmetrical airfoil at 0 AoA? xlcrlee Modeling Science 99 Oct 03, 2015 04:27 PM
Discussion XK X250 Really has a air pressure needle to fix height? Is it accurate? RealRCGeek101 Mini Multirotor Drones 10 Sep 20, 2015 02:12 AM
Question Fuel tank, pressure feeds and pressure in general Eaglebird Engines 36 Jun 10, 2007 02:50 PM
