Balancing tails and mains as a whole? - RC Groups
Jul 27, 2017, 04:28 PM
How would i go about balancing main and tail rotors.
its all very well getting the blades balanced but then your attaching them to something thats probably not exactly balanced either..
Tails shouldnt be too difficult as a tail hub has a whole at both ends so you can get it on a prop balancer or hi point balancer.
but what about main rotot... you cant push a shaft all they way through and out the other side...
Jul 27, 2017, 05:40 PM
banging head on wall
skyeblu's Avatar
https://www.dubro.com/products/tru-spin-prop-balancer . What I use for balancing main as a unit . There are videos around showing balancing main shaft and complete head assembly minus blades .
Du - Bro Balancer (2 min 20 sec)
Jul 27, 2017, 05:46 PM
Bro!
denis747's Avatar
You can use a spare main shaft and support it using two main shaft bearings on two stable supports. Remove the head including the main rotors and install it on the spare main shaft then you should be able to balance them that way. Of course you have to make sure that both blades have identical center of gravity.
Jul 27, 2017, 07:52 PM
I do it by removing the lower jesusbolt only! Head still in heli tilt heli and balance as needed of course you need to make sure your main shaft bearings are good first
Jul 28, 2017, 04:18 AM
All great info!!!!! Ill give it a show by removing the main gear. i think just removing the jesus bolt would still allow some resistance,
Im wanting to get a trupoint/hi point balancer as im pretty sure the fan/clutch on my 600 nitro needs balanced it was never done when the previous owner built it.
Jul 28, 2017, 06:57 PM
Team Compass/KBDD Team Pilot
Ah Clem's Avatar
Back in the old days, it was a good practice to use a high point or similar balancer to account for imbalanced or asymmetrical head components with Kavan, Kobe Kiko, and other, older machines.
With a good quality, modern helicopter (Compass, Align, MSH, SAB, Velos, Mikado, etc.), this is not necessary.
It is important that the blades weigh the same, and have matching span-wise and chord-wise CG's.
It is also important that nothing is bent (spindle, head block,blade grip, blade grip arm, etc.).
Jul 28, 2017, 07:17 PM
dynamic balancing
I read about an app on the Copterx thread to make your cellphone a sensor for balancing. It looked pretty cool.
I didn't pay attention enough to download or remember the name of the app because I use Audacity.com (freeware--an acoustic program) to show me the rpm (convert from Hertz) and amplitude of an imbalance.
https://www.rcgroups.com/forums/show...ctral-analysis
I use this method on main rotor with no blades, tail rotor no blades, then add blades.
Jul 29, 2017, 02:43 PM
i have a kbar which has vibration analisis but its a bit of a guessing game unless you really know what your doing. by doing it the way im intending to do it you knkow that the head is balanced and if vibration is an issue its somewhere else.
Jul 29, 2017, 03:36 PM
vibration analysis
With some calculation you can pinpoint where your vibes come from. Mainrotor spinning at 4500 rpm and tail rotor at 4 X that or 18,000 rpm . I look for spikes in the Audacity's display at 75 and 300 Hz. Miinimize each. The larger the spike the more correction you need to apply. The only guesswork is in which blade to start with.
I have rattled apart a couple of tail rotor assemblies @ 18,000 rpm before I could get them balanced. That's why I started balancing at a much slower speed. Get it good at 20-35 Hz then 75 shouldn't be too much different. Some guys run over 5,000 rotor rpm and tails 20,000,
Do some math and see the spikes that the motor creates. Or run the motor free with no gears. But math is still good to do.
Gyros work better with smaller vibrations. The whole heli works better balanced. Kinda like waxing your skis.
Jul 30, 2017, 04:17 PM
well i removed the main gear and it looks like the main rotor is pretty closely balanced couldnt get it to stick in any 1 position and the blades always fall pretty much level or just off by a tad either direction.
Aug 01, 2017, 04:51 AM
+1 for the dubro balancer. I just balance the whole assembly. You can balance just about anything with it if you get creative in setting it up. I never do the tail. you are adding your weight to the cog?
I also use a gram scale which makes sure you get it balanced within 1 or 2 tries. 20 bucks or less, .1g is more than sufficient.
When you get it perfect they sit level, no movement whatsoever, all day if you leave it.
find the cog with a pencil or spare main shaft, haven't ever had one off from a matched set of quality blades
static balance = identical weight
dynamic balance = identical weight && matching cog
tail vib is pretty common - highest frequency vibs from a spectrum analyzer or vib analysis
bearings most likely to cause vib? I'd say generally the main / tail shaft bearings.
The bigger stuff is real hard on bearings that have seen a crash
don't overlook the grip bearings, seen notchy ones cause some absolutely baffling symptoms due to the fbl trying to fight them
heard of motors being a source of vibs but ive only seen magnets come loose, they came apart before i had time to worry about vibs.
i've totally gotten away without checking them on a balancer. just within .1g + matched cog flies just fine in my experience
this one is purely anecdotal but I had a set of cf tail blades on my 250 that simply would not fly right, i could never figure out why, i just guessed one was weaker than the other and tossed them.
Aug 01, 2017, 05:54 AM
My blades are fairly decent although the mains are a bit beat up but still balance. Ive never found a set of blades that had exactly the same COG even align blades were off by a small amount.
ive got RJX blades on the 450 mains and tails. They balanced on my blade balancer right out of the box but the cog is not likley to be the same.
Main bearings are new as is the main shaft. feathering shaft , raidal and thrust bearings. I need to look at the kbar vibe anylisis but last i looked im sure there was some stuff down low. with a couple spikes in the tail, hwoever teh pics were well bellow the yellow line.
Aug 15, 2017, 10:40 PM
Professional heli wrecker
Luvmyhelis's Avatar
Pick up a cheap Dubro balancer. I use it on just about everything. Even name brand helis have seen some serious issues, all of them! Balance the head while seated on the main shaft, then the tail just the same. Add the grips and do it all over again. I use a very thin rubber band to hold the grips in the correct position so each side is perfectly equal. Blade balancing is an art. First weigh both blades, use the heavier one to find cog. In the old days we used a Koll balancer for doing this more easily, but, the company is gone. There are lots of how to vids on YouTube. Then weight balance the lighter blade so it matches the cog of the heavier one and then add weight to the center until they are identical. Pretty much bullet proof and the proper way to do it. Out of hundreds of sets of blades I have balanced over the years, Only three actually matched up to my standard of what is right.
Aug 16, 2017, 09:26 AM
Pretty much looking to do this for the reasons you stated. I get issues after i putting blades on, the vibes arnt bad but i know i can get it better. For instance with blades of i could be as low as 300 in kbar but once the blades go on it kicks up past 1300 and im seeing a few spikes (although not big spikes)
Even with blade COG matched and then balanced there must still be something in the head thats throughing it off. I confirmed that by adding tape to a blade and seeing if there was improvement which got it slightly better.
its going tohave to wait though as my heli had a bad crash after the tail let go so alot is needing replaced.
Aug 17, 2017, 02:49 PM
What tools do you need to remove the main blades on a genius 500
Discussion What an embarrassing election for America as a whole. Goonie Works Life, The Universe, and Politics 40 Oct 20, 2016 04:31 PM
Help! My Kyosho Jet stream 800 startsrunninjg as soon as I plug in main battery Trapper_Jon Dock Talk 4 Oct 25, 2015 01:54 AM
Discussion Whole Tail gear box swing, twist when max throttle test (no main blade installed) rcjpth Electric Heli Talk 3 Feb 05, 2009 09:11 AM
Poll What do you use to balance your 450 tail rotor? NOT MAIN ROTOR LaurenceGough Mini Helis 31 Oct 19, 2008 06:36 PM
Tail shaft size on the Zoom? Final output ratio for it as well vs main shaft? Admiral_Red Mini Helis 1 Jun 08, 2004 04:40 PM
