This is an accurate scale model of the USS Nimitz nuclear powered aircraft carrier which was commissioned in 1972. The Graupner USS Nimitz is one of our Premium Line of historical ships that arrives Almost Ready to Run. The motors and rudder servo are already placed, and only the radio and electrical system need be installed before the boat is water-ready. For reliability and performance, we highly recommend a Graupner radio such as the mc-16 which provides real-time telemetry information of the condition of your ship.
USS Nimitz Graupner Super Premium (1 min 40 sec) |
The Graupner Premium Line ships are carefully handcrafted and assembled using CNC processing to replicate the model as originally as possible. The hull is made from molded GRP complemented by the superstructure and deck which are constructed from laser-cut ABS parts. Many of the small items are made from metal, and almost everything is factory-assembled. The hull, parts of the superstructure, the masts and fittings are spray painted using semi-matt paints. Decals are already applied. With so many details and scale fittings, the Premium Line ships all have an impressive scale appearance.
The USS Nimitz can be further enhanced and expanded with a variety of Graupner expansion modules such as lights, sounds and operating radars with our Nautic modules.
USS Nimitz is the Navy’s oldest and finest aircraft carrier!
Thread Tools |
$1480, not bad considering. Should be 5-1/2 feet long.
I'd want to see inside, and verify that they installed the prop shafts correctly... . |
I took a chance and purchased the Graupner 1/48 HMS Bluebell, a WW2 corvette. The build is really quite nice, but exceptionally fragile. The internals are spot on and nicely laid out and accessible. I found two things to beef about, first, the instructions were very scanty. They recommended a 7.2 volt pack for power. Not having one, I used a 6 volt SLA, The ESC has it's own BEC, which I used. At 6 volts, she does approximately 5 times scale speed, a tad excessive. can't imagine her on 7.2 volts. Also I found the rudder swinging an easy 45 degrees,, so excessive as to slow her down during hard over turns. Easy to fix. Next I found a number of pinhole leaks in the hull. All along the bilge keels. The hull is a VERY thin layup. Careful tank testing, and being prepared to do some patch work is advised. Over all, for the price, I could not have built it for the same amount.
That's always a problem with scale boats (and their operators)... ease up a bit, it's not a race.
Otoh, watching most real ships move at normal speed ain't exactly breath-taking... |
i purchased the graupner bismark a few years back. really a beautifully detailed ship, although the deck is quite fragile with this type of detail so it takes calm steady hands when handling. the inside is laid out clean and tidy with 3 drive lines. ship has about 15# of padded removeable ballast if I remember. I run a single esc with a cooling fan powered by a separate life. motor powered by 2s, 10,000mah lipos which rest center middle length of hull for easy removal. the ship is really quite a scale sight to be seen and commands attention at the ponds.
Q: What is the exact length of this model? Asked by: Aeronca52 - 7/29/2017 A: The USS Nimitz is 68 inches long. |
Holy moly! Would love something like this. But at £1140, I could never spare such money, haha!
Thread Tools | |
Similar Threads | |||||
Build Log | REDBOX Uss Nimitz Toy to RC conversion | Kenwhite23 | Dock Talk | 4 | May 30, 2016 08:45 PM |
Build Log | Scratchbuild 1/200 USS New Jersey post 1983 version | pulsar110 | Scale Boats | 26 | Feb 15, 2010 09:50 PM |
New Product | 1/200 Uss Missouri Maiden Voyage | arkmodel | Scale Boats | 10 | Oct 14, 2008 09:08 AM |
Discussion | USS New Jersey BB62 1/200 scale | pulsar110 | Scale Boats | 5 | Sep 26, 2008 05:08 PM |
Discussion | Uss Missouri Bb63(1945) 1/200 | arkmodel | Scale Boats | 6 | Sep 23, 2006 01:50 AM |
