Jul 22, 2017, 09:10 PM
Everything is broken
JimZinVT's Avatar
Question
HS82mg servo - will Karbonite gearset fit?
Hi - wondering if the metal gearset in my HS82mg servos is interchangeable with the Karbonite gearset? They've developed some slop, and the replacement metal gearset is 2 -3x the price of the Karbonite. Almost the price of a new servo, from some sellers.
I've also read that you can turn one or more of the gears 180* on it's shaft so that less-worn teeth are meshing. Any experience with that?
Thanks.
- Jim
Jul 23, 2017, 01:22 AM
Julian T
No experience with turning the gear)s) but doubt it would work. I have replaced metal with karbonite to eliminate slop in a gear train - it works well and providing the gear train is not subjected to hard shock will last virtually indefinitely without slop.
Julian
Jul 24, 2017, 12:38 PM
Team AJ Aircraft / Team JR
Xpress..'s Avatar
There is no Karbonite gearset available for the HS-82MG. You can use either the HS-81 gears or the HS-82MG gears.
Jul 24, 2017, 05:29 PM
JimZinVT's Avatar
Yes, I discovered that as I searched for the replacement sets. HiTec made a lot of servos with Karbonite gears, but never the HS-81/82. I found the resin gear set (why don't they just call it what it is....plastic!) for $2.70 or the metal for $10.
I may try opening one up and try turning the gears tonight, just to see if there's any improvement. I'm not sure which gears typically get the most wear, but I'd guess most of the wear is around the center point of the servo so there should be part of some of the gears that is less worn.
Maybe too much effort for $20 servos
Discussion Is the HiTec HS485 Karbonite Servo a good choice? G.F. Beurling Fuel Plane Talk 30 Oct 05, 2016 11:01 AM
Discussion speed vs. torque: servo gearsets interchangeable? hancockdw Servos 5 Jan 22, 2016 06:59 PM
Discussion Mini/std. karbonite gearsets [email protected] Vendor Talk 1 Sep 14, 2007 02:21 PM
Are these servos strong enough for the Logo 10? Will they fit? Jason M Electric Heli Talk 1 Feb 25, 2002 08:33 AM
will HS-80 gearsets work in HS-81 servos ericstac Electric Power Systems 3 Jun 01, 2001 03:16 PM
