This thread is privately moderated by Mad_angler1, who may elect to delete unwanted replies.
Jul 22, 2017, 12:11 PM
Bog Flusher Platinum Grade
Mad_angler1's Avatar
Mini-Review
Evolution3D DJI CrystalSky Mounting Kit for DJI Mavic Pro
I Just received the Evolution3D CrystalSky Mavic Mounting Kit
After a few hours playing I'm really impressed with this bracket tbh it's perfect for me, mounts both the 7.85 and 5.5" models in 2 positions depending on your preference, has adjustable tilt and is quick and easy to fit.
The Bracket
Evolution3D specialise in 3D printed parts and as a printer owner I can honestly say the print quality is 1st class, these brackets are extremely well made and it's a great design, every part of this kit that's not metal is printed and it's all solid and well designed.
There are 4 parts in the kit
You have a mounting plate that screws to the bottom of the CrystalSky with 2 supplied screws, this has a large thumb screw as well as a hole for the USB C port access.
The RC clips into the main back bracket and give two points for mounting as well as a strap mounting hole, it clips in easily and remains solid and licked in place.
Once fitted you just choose to fit either the top support or the bottom one or even both, the two mounting options are
The first is above the RC
This puts the CrystalSky at the top above the RC, it does clear the antennas nicely and when I first tried this I thought this would be my preferred option, the only down side is it is too heavy here very much more so with the 7.85".
The second position is above the sticks
Once I tried this is was like wow I like a lot, tons of clearance for hands and he antennas are even more clear now, while it blocks the LCD it's not an issues with the go app tbh.
Overall I'm loving this bracket, it's exactly what I was looking for, it's simply perfect for me, if your looking to mount the CrystalSky on the Mavic or Spark the go check out www.evolution3D.com and check out what they have.
Jul 26, 2017, 12:25 PM
Go Hawks!
cryhavoc38's Avatar
how is the connection cable routed?
Jul 26, 2017, 12:28 PM
It was provided FOC but that has no bearing on my opinion.
If it was I would tell you it it was, currently suits my needs perfectly, I would expect it to do so for others too.
Jul 30, 2017, 10:10 PM
1000 Islands NY State
dotster77's Avatar
lots of ways to route your cable.. see images..
Aug 01, 2017, 02:17 PM
Go Hawks!
cryhavoc38's Avatar
i modified my post shortly after the original was placed, but it would appear you saw it so I will follow up.
If it was provided FOC, and for that matter, any item you review that was provided FOC, you should state that right up front. Be transparent.
Ie, this item was sent to me Free of Charge for purposes of a review.
Just a suggestion.
Discussion DJI SDK Apps - Spark-P3-P4P-Mavic Pro-Air-Pro2-Inspire1 & 2-M100-M200-M600-A3-N3 MultiRotR Multirotor Drone Talk 2231 Dec 20, 2018 10:19 AM
New Product Free DJI Mavic Pro Landing gear and gimbal cover kit in USA NancyHelistar Micro Multirotor Drones 0 Jul 01, 2017 01:42 AM
New Product Free DJI Mavic Pro Landing gear and gimbal cover kit in USA NancyHelistar Multirotor Drone Talk 0 Jun 30, 2017 10:51 PM
