Power supply for standalone microsensors - RC Groups
Jul 21, 2017, 04:42 PM
ı ɐɯ uoɹɯɐן
Curtis in Texas's Avatar
Just delivered and waiting for me to get home are the v4 altimeter and v3 airspeed microsensors and I am not an electronics guy. If it's the only unused port, can the Bind port of a Spektrum Rx be safely used to power these sensors?
Edit: One sensor at a time, not two powered off the same port.
Edit: But, in case I want to use both sensors and only the Bind port is free, can they both be safely powered from one port?
Jul 22, 2017, 01:58 AM
The sensor are designed be be connected to a normal servo port when used in stand alone mode.
So if the bind port is connected to the servo power rail, (which I think it is because I think you can power the receiver from the bind port), then it should be ok.
Using your multimeter check the continuity between the bind ports power and gnd pins to a servos power and gnd pins.
Jul 22, 2017, 10:20 AM
No bounce, No play.
davidmc36's Avatar
Bind/Dataport on Spektrum Rx's is parallel to other ports. Will work fine. Just like it powers TM.
Aug 26, 2017, 09:36 PM
ı ɐɯ uoɹɯɐן
Sorry guys, I completely forgot I started this thread but thanks so much for the replies / info.
It didn't take long for me to figure out that since I swap planes often during the day, snaking a power lead from top-side main batt compartment (only place large enough to carry altimeter) to bottom-side Rx location, I needed to power the microsensor off it's own batt.
Cool ET Announces Standalone G-Force MicroSensors, starting at $26.99! billpa Eagle Tree Systems 20 Jun 30, 2016 09:57 AM
Article Eagle Tree Systems Altimeter and Airspeed Standalone Microsensors Review Tram Flight Accessories 16 Mar 25, 2016 03:54 PM
Discussion Power Source for Standalone Gyro on gimbal? killerforhire Aerial Photography 1 Jul 23, 2009 12:05 AM
Discussion Power supply for home and compact power supply/charger for road! Whistler71 Batteries and Chargers 5 Oct 19, 2007 10:21 AM
