ARRIS X-speed 180 rtf comes with the Emax RS2205 2600KV brusheless motor,ARRIS Raptor 30A ESC,4045 propeller,F4 flight controller and ARRIS XAT700M FPV mini camera and radiolink AT9 transmitter. It is fully assembled, tuned and tested before leaving the factory. Small Size, Light Weight,Strong Powerful,Fast Speed, this is ARRIS X-Speed 180 FPV Racing drone. If you pursuing a speedy and powerful fpv racer, this one is your best choice.
Unibody Design,Small Size and Light Weight
ARRIS X-Speed 180 adopts "unibody" design.The main unibody 3mm plate is CNC processed out of solid 3K carbon fiber sheet. The weight of the frame is kept low while the strength is kept high. The diagonal wheelbase of the ARRIS X-speed 180 is only 180mm, much smaller than the 250 or 280 racers.
X180 has pretty simple wring method, with all wires hidden inside the frame, which could not only reduce all kinds of wiring mess, but also effectively protect cables and electronic components assembled on it.
Strong Power and Fast Speed
ARRIS X-Speed 180 equipped with the ARRIS Falcon 30A ESC,EMAX RS2205 2600KV brushelss motor,4" propeller and F4 flight controller. With this setup, the X180 would have better performance. We joked that this ARRIS 4in propeller should have let us cry, because it is too strong to damage, even after a heavy crash, it is still the same, no bent, no broken. What can we say? This will save customers much on purchasing the spare propellers.
ARRIS X-Speed 180 comes with EMAX RS2205 2600kv high efficiency brushless motor.
Key Features:
1K+ Thrust with 4s battery and recommend propeller combo
Cooling Series Bell Design reduces motor temperature by at least 30%
Highest Grade N52 Neodymium magnets
Genuine Japanese NMB Bearings
Each Motor is Dynamically Balanced in the factory.
15mm Extended Prop Shaft allows virtually any prop with 5mm hole.
3 Lock nuts and 2 sets of motor screws for 3mm and 4mm thick frames.
Windings made from copper of high purity.
This package includes :
1 X ARRIS X180 Racing Drone kit
1 X RadioLink AT9 9-Channel 9CH 2.4GHz Transmitter
1 X RadioLink R6D Receiver
1 X F4 Flight Controller
4 X EMAX RS2205 2600KV 2600KV
4 X ARRIS Falcon 30A ESC
4 X ARRIS High Quality 4045 2-Blade Propeller
1 X ARRIS XAT700M FPV Camera
1 X 5.8G Antenna
1 X ARRIS Mini Power Distribution Board
1 X 5.8G 200mW Video TX
1 X Battery Warning Buzzer
2 X ARRIS Battrey Strap
