H-King Wargo YAK 55 EPP KIT - RC Groups
The H-King Wargo Yak55 just hit the market. It's an EPP 3D foamie and HobbyKing worked with 3D pilot Michael Wargo on the design.
Hover, Harrier and Tumble Like a Pro
The H-King Wargo Yak55 just hit the market. It's an EPP 3D foamie and HobbyKing worked with 3D pilot Michael Wargo on the design. Michael says "The Wargo Signature Yak 55 is the realization of my goal to have the perfect 3D and aerobatic training aircraft." He has taught many pilots to fly 3D aerobatics and this is a great plane to do that with. Being made from EPP with carbon fiber reinforcements, you'll be able to practise lower with more confidence and build your skills faster.
This is a kit, so you'll need to provide your own power system and radio gear. It uses a 30-35 size brushless motor and H-King recommends their 3530-1150kv Turnigy Aerodrive outrunner and a 10 or 11" prop with an Aerostar 30A ESC. The wingspan is just over a meter so it will fit in smaller cars. For the rest of the electronics you'll need to have some 3S 1300-1800mAH lipos on hand and four 9-12g servos.
Check out the H-King Wargo Yak 55
Jul 20, 2017, 12:13 PM
I think many people recognizes this, I have had it for a couple of years allready in a different scheme. But it flies really well, very easy to do some 3D stuff for people who arent really good at it, like me. It can hold a kife edge as long as you like with very little input.
Jul 20, 2017, 01:17 PM
Hmmmm. Is' nt this the same plane thats been talked about and waited for in another thread since March? Might want to combine this thread in to that one to keep it from getting so convuluted. Just a thought.
Jul 20, 2017, 02:29 PM
RCG Staff
Jason Cole's Avatar
This is a news article and gets seen in different places than just a normal thread.
Jul 20, 2017, 04:30 PM
I see. Thanks
Jul 20, 2017, 07:12 PM
Don't give in to gravity
Gravitycheat's Avatar
To bad they don't offer/recommend a power system with it. For many newer pilots, that would make it much easier to purchase
Jul 21, 2017, 03:12 AM
Mike's Ma Maaaaaaaaan
PaulB's Avatar
Bit confused, which part of this :-
Required:
1 x Turnigy Aerodrive SK3 - 3530-1150kv Brushless Outrunner Motor or HobbyKing Donkey ST3007-11OOkv Brushless Motor
1x Aerostar 30A Electronic Speed Controller with 2A BEC (2-45)
1 x Propeller: 10*4.7 SF or 11*4.7 SF
4 x 9-12g micro servo
1 x 11.1V 3S 1300 - 1800 mAh Li-Po 25C
1 x 4 or more channels Radio / Receiver
that you are not seeing.........
All shows on my browser but if you are still stuck the 'other' thread clearly lists all items required to complete the build (don't forget the 4 mm prop adapter).
Paul
Jul 22, 2017, 08:12 AM
Yup, had this plane in the past under the old colour scheme, bit confused how MW designed it cause it's the same, even the fittings are the same but black glass parts now and definitely not carbon like he says in the video (even the hk build daily video state glass parts) so nothing new apart from the colour of the plane.
But they do fly really well, I gave my old one to my mate so glad they brought it back and I managed to get another, for the price you can't go wrong.
Jul 23, 2017, 11:35 PM
Bay Area Prop Buster
Bluhammer's Avatar
Looks like my TechOne SU31.
Jul 26, 2017, 03:58 AM
I found my old HK Yak55 needed a SK3 3530 motor as the 28mm did not really give 3D performance. At least the Wargo allows for this without having to modify the motor mount
Jul 26, 2017, 06:55 AM
Sorry guys! I gave HK too much credit for common sense. I have just physically tried a WARGO kit and the motor mount is exactly the same as the old Yak55. This means the mount would need to bigger laterally by 1mm each side for an SK3 3530 V1. For a SK3 3530 V2 (which has a different mount) it would need to be 2mm laterally and 1mm vertically each side. I could have the versions wrong as the mounts may have been swapped between boxes but check your motor before modding.
Discussion Hobbyking's MIchael Wargo Signature Yak 55 EPP Foamy mtwargo 3D Foamies 965 Today 05:51 PM
Discussion HK Yak 55 EPP 1096mm alouette 3D Foamies 1101 Oct 08, 2016 02:39 PM
Video Hobby King Yak 55 3D EPP spanker Electric Plane Talk 0 Jul 05, 2012 10:22 AM
Discussion RCF 39" Yak-55 or Telink 43" Yak-55 3flyguy3 3D Foamies 8 May 11, 2012 09:52 PM
