New Product
Sonicmodell AR Wing FPV
Sonicmodell AR Wing 900mm Wingspan EPP FPV Flywing RC Airplane KIT
Banggood just released new FPV wing, kit version and PNP. Fits gopro or runcam and hs1177 for FPV camera. Seems to be well designed and looks ok. Would the PNP version be any good or would it be better to get kit and buy some other electronics? Description: Brand Name: Sonicmodell Item Name: AR Wing Mini Skyhunter Wingspan: 900mm(35.43") Length: 482mm(18.97") Flying Speed: 10km/h - 80+km/h Features: - Black EPP molded wing and fuselage, plus pre-built in carbon fiber spar, durable, light and flexible. - Detachable wing and wingtip, portable and easy to take for out door FPV fly. - Multiple bonus camera mount, compatible for all FPV HD camera in the market. - Easy to hand launch, super stable flying performance, 10km/h - 80km/h flying speed. - Wingspan 900mm with high efficiency airfoil, create powerful elevating force. - Spacious equipment bay for more FPV gear. - Movable battery slot for better “CG” adjustment - With bump for “CG” mark under the mainwing. - With 2 skids for hand launch grip and landing. - With "NACA" Air inlet and outlet for FPV gear cooling. Note:This item does not include any electronic devices. Sonicmodell AR Wing 900mm Wingspan EPP FPV Flywing RC Airplane PNP Description: Brand Name: Sonicmodell Item Name: AR Wing Mini Skyhunter Wingspan: 900mm(35.43") Length: 482mm(18.97") Flying Speed: 10km/h - 80+km/h Motor: 2204 2200kv(Shaft Diameter: 5mm) ESC: 20A 2-3s(XT60 connector) Servo: 2pcs 9g digital servo Propeller: 6x3 ( 5-6" multirotor props also compatible) Features: - Black EPP molded wing and fuselage, plus pre-built in carbon fiber spar, durable, light and flexible. - Detachable wing and wingtip, portable and easy to take for out door FPV fly. - PNP version, prestalled motor, servo, ESC - Multiple bonus camera mount, compatible for all FPV HD camera in the market. - Easy to hand launch, super stable flying performance, 10km/h - 80km/h flying speed. - Wingspan 900mm with high efficiency airfoil, create powerful elevating force. - Exactly the same motor / ESC / prop with racing quads, exchangeable between each other. - “No-glue” required assembly. - Spacious equipment bay for more FPV gear. - Movable battery slot for better “CG” adjustment - With bump for “CG” mark under the mainwing. - With 2 skids for hand launch grip and landing. - With "NACA" Air inlet and outlet for FPV gear cooling. Note:This item does not include transmitter, receiver, battery, charger, Vtx and cameras. |
Man that looks awfully similar to the NEW Recruit from Ready Made RC??
Check it out! https://www.readymaderc.com/store/in...oducts_id=6871 Same airframe for 84.99 PNP with a 2 mode stabilizer. Plus I am not looking to bank off of a referral link tisk tisk. |
I think you find the RMRC Recruit and the Sonicmodell AR Wing 900mm are the same thing, just one is RMRC branded an one is not. Both put up on website on the same day also.
The ZOHD orbit, the fuse looks similar but wings are different. Also ZOHD orbit I can see how the elevons are moved as there is no external sevros etc. |
Howdy,
To clarify, the RMRC Recruit will be same airframe as the Sonic modell AR Wing and not a "clone" because they will have come out of the same mould and manufactured by the same company which "Sonic modell". This is an example of RMRC working in partnership with a 3rd party model manufacturer to tailor a model to a specific market, including branding (stickers) and potentially some part changes too. Also ZOHD is a trading name of "Sonic modell" (see here), so expect to see a couple of versions of the same model & variations being deployed on the back of the success of the Reptile S800 wing, such as the ZOHD orbit. We see the word "Clone" being thrown around, when in reality, the model was made in exactly the same mould (because moulds are realllly expensive), in the same factory and branded up differently. Just like we see in many other areas, such as consumer electronics, food, fashion & so on... And finally, it's fantastic to see RMRC working with a factory to customise a model to a specific market. If only their shipping to the UK wasn't $65!!! Matt |
Reason: lost all ability to spell, obviously not enough coffee yet
Ok, so RMRC is just rebrand version of this. Although it was fair guess that it would be clone as you know what chinese do quite usually.
Shipping and customs makes everything way too expensive to order from US to Europe, so it's great that more models are available to purchase cheaper from china without buying clone |
Also Banggood sell a lot of planes and wing that are original nit like their quad fames. |
there are too many choices. i was set on the orbit 900, i like the internal servos. but i like the second camera mount on this this and the rmrc.
Reason: Didn't finish
flew stock w/6x3 prop on 2200 3s kinda slow but 12min mix flying came down at 11.4! added an 2207 f60 pro 2500kv w/5x3x3 6min 10.9... 30 amp esc looks like a joke theres more heat shrink then esc but still alive after 8 flights. love the look and feel of the black epp!
Thread Tools | |
Similar Threads | |||||
New Product | HobbyKing / SonicModell / UniqueModels PT-17 Stearman wing struts | prezes_wojtek | Electric Plane Talk | 10 | Jan 01, 2020 11:09 AM |
New Product | SonicModell SkySurfer 1500 FPV plane - light and efficient (full review & build log) | Arxangel | FPV Aircraft | 22 | Sep 28, 2016 03:57 PM |
Alert | Sonicmodell 43" (1100mm) P-51D | BSintzel | Electric Warbirds | 7 | Aug 28, 2016 10:51 AM |
New Product | Sonicmodell Mako Flying Wing 1213mm Wingspan FPV RC Airplane PNP | Whitehouse | FPV Talk | 0 | Feb 10, 2015 08:01 PM |
