Apr 30, 2019, 10:15 PM
Scale Builder
Looks real familiar. You're almost to the fun part now!
May 01, 2019, 02:45 AM
grahamj4's Avatar
Haha thanks Chad. Starting on the cockpit now so I can get the canopy into place then finish surfacing/panel lines etc... you know, the little things that all together really stand out.
May 04, 2019, 05:47 PM
Typhoon
I built Brian Taylor's Typhoon and used a servo for each aileron, but I did use one servo for the flaps as it shows on the plans.
I am using a Saito 120 for power. The only problem I have had was getting a proper set of retracts of which I think I finally have the solution. I am using E-Flite 60-120 electrics.
Good luck on your build. It is will be a great looking airplane
Curt
May 18, 2019, 09:57 PM
grahamj4's Avatar
Hi all, as mentioned at the start of this thread,this particular model was started by a family friend that flew them in combat with 486 Sqn RNZAF. I recently acquired the book "One More Hour". In it is this photo of 486 Sqn and there he is, D.G. Fail (Dave), sitting on the wing.
May 18, 2019, 09:59 PM
grahamj4's Avatar
Meet Dave, and in his new home.
Jun 26, 2019, 03:05 AM
grahamj4's Avatar
Haven't had much build time lately (plus it's been damn cold in the shop!!) But I did get the pilot and cockpit parts painted and ready for installation.
Also had a new canopy and spinner arrive from Sarik hobbies, best get back into it :-)!
Jun 26, 2019, 03:11 AM
Registered Slopeaphile
awmeade's Avatar
Great job on the instrument panel and pilot, will be great all installed.
Jun 26, 2019, 06:08 AM
Prekin's Avatar
Great job, looks really good.
Not sure if the parachute belts are yellow. In the picture they look so. Only friendly advice, they should be white
Jul 17, 2019, 02:36 AM
grahamj4's Avatar
Hi all, I got the cockpit and pilot installed, to be honest I've never been good with building cockpits (one advantage of pattern f3a models!) but I'm happy enough with this one.
Took a little sequence planning to squeeze it all in but it did all fit!
Aug 12, 2019, 03:37 AM
grahamj4's Avatar
Made a little more progress lately, I've put clear plastic over the wingtip and landing lights then faired those in to the wing surface. Brand new canopy from Sarik hobbies has been glued on and faired in. Then the fiddly task of laying out the tape for panel lines. I've elected to get the basic surface to be "Pretty good" then added the tape, I've used 1/64" chart tape and its finicky. My plan is to then be generous with the primer and block sand it back until the tape and white primer is showing, pull the tape out and I'll have a nice small groove left...
The little dark blue lines are the tape :-)
Aug 12, 2019, 08:15 PM
limodune's Avatar
Nice job with the build it's coming along
Build Log Bob Holman/Brian Taylor 71" Bf-110C totenkopf Fuel Warbirds 10 Dec 18, 2015 08:14 PM
Help! WTB - Cowl for a Brian Taylor Hawker Typhoon codell Fuel Warbirds 5 Dec 11, 2013 04:49 PM
Help! WTB - Cowl for a Brian Taylor Hawker Typhoon codell The Builders Workshop 0 May 31, 2013 04:48 PM
Contest Funbuild II Contest Hawker Typhoon adapted from Brian Taylor Plans Foamenator Scale Kit/Scratch Built 34 Oct 09, 2009 06:20 PM
Brian Taylor Typhoon hawker3119 Scale Fuel Planes 0 Jan 20, 2004 05:06 PM
