Seawind sailboats - RC Groups
Jul 14, 2017, 05:13 PM
Seawind sailboats
Anyone know of Kyosho Seawind sailboat HATCH COVER UPGRADE ??
Jul 14, 2017, 05:36 PM
a.k.a. Bob Parks
Look on the AMYA web page under Boats - Seawind. In the Seawind Express newsletters are a couple of choices to make. There is an index of Hints & Helps in the first few pages of each issue.
link
http://www.theamya.org/boats/seawind/seawindexpress.php
BP
Jul 14, 2017, 10:03 PM
alan_k's Avatar
Go to the Air Capital Model Yacht Club website, in Wichita, and look for sales. Rob Fresh sells a great hatch cover there. I have two.
Jul 14, 2017, 10:32 PM
Po' boys does w/ Po'boys ways
haxawsnavy's Avatar
HB, There are MANY ways to upgrade the main hatch n there's some good reading from this thread also,!! https://www.rcgroups.com/forums/show...seawind/page41 and following pages. Everyone has a pref and as long as it keeps the inside DRY ,!!!.....We probably have 4 or 5 different variations in our club alone that I KNOW of,!!! (QCMYC) Tim aka Cap'n Hax
Jul 14, 2017, 10:39 PM
https://sites.google.com/site/wichitarcsailing/for-sale
For some reason I thought I had read last year that he had stopped selling this hatch. Just looked at the site and it is still listed in the for sale section so guess I was wrong (wouldn't be the first time).
Jul 14, 2017, 11:14 PM
Ed Dawson
Easy-Ed's Avatar
Just purchased one, installation was last night, hope to remaiden tomorrow.
Jul 15, 2017, 10:44 PM
haxawsnavy's Avatar
Ez-Ed, Can you possibly share some of the re maiden (Vid or Pic's) take your choice, and your personal review /results with us, after,?? Thx in advance,! Tim aka Cap'n Hax
Jul 16, 2017, 08:28 AM
Ed Dawson
Easy-Ed's Avatar
Sure. Need some wind though. I will snap a couple of photos of the hatch cover also.
Jul 16, 2017, 11:18 PM
flatlandsailor's Avatar
I can confirm that Rob Fresh IS indeed selling hatch covers. Just contact him using the 'for sale' page:
Andy
Jul 24, 2017, 10:08 PM
alan_k's Avatar
Sheet Mechanical Advantage
On the Seawind, the sheet is directly attached to the Sail Control Servo Arm. Is this required? My Victoria has the sheet end attached to the hull and goes through a bead on the servo arm end, to then extend to the boom or jib club. That is a two times mechanical advantage, saving the servo motor from strain. The Seawind has more servo motor strain than a Victoria. I had to replace a Hitec HS-765HB motor that couldn't pull in sails, in high wind. What are your thoughts? Please do not lecture on how to run sheets.
Jul 25, 2017, 12:01 AM
Boomer1
Boomer1's Avatar
Alan
I've not experienced any torque issues in any of my Seawinds. Posted pictures of two of my Seawinds. One was equipped with a S 5301 which produces 292 oz of torque at 6V. The servo I use normally is the Futaba S 3801 that produces 194 oz. of torque at 6V. The servo you are having performance issues with the HS-765HB produces 183.3 oz.of torque at 6V. Doesn't seem like much difference from the Futaba S 3801.
The Futaba S 3801 is the servo that was originally specified by Kyosho many years ago for these boats. If you look closely at the CF edition you may notice I made a slight modification to the factory recommended sheet set up. Worked fine. The orange boat was set up per the factory specifications. Works fine in any wind conditions.
I say if you have a better idea, try it. Like to know if it works!
Boomer
Jul 25, 2017, 01:09 AM
haxawsnavy's Avatar
Boomer , Thanx for sharing the upgrade pic's n intel info,!! Tim aka Cap'n Hax
Jul 25, 2017, 03:54 AM
The doubling at the servo arm in the Victoria doubles the sheet travel, not the force. In fact, it halves the available torque but doubles the strain on the servo.
If a HS-765HB can't pull in a Seawind's sails in weather that a Seawind can handle, either the winch is not performing or its power supply is not up to standard.
If using an arm, I usually try to fix things so that the line is parallel to the arm when close hauled.
Jul 25, 2017, 04:14 PM
Alan, I use both the HS-765HB and the S-3801 in my Seawinds and have never had any issues when sailing in conditions the boat is capable of - Both servos have more than enough torque for the boat so if your servo is working properly and is not pulling the sails in - than it's not the servo but some other issue that's creating excessive drag on the sheets - fox
Jul 27, 2017, 02:06 PM
External power switch
Seems like I remember in one of the Seawind threads reading about someone using an external power switch on their boat. Have gone thru some of the older threads, did a search but just can't come up with a link.
Does anyone on here remember this and if so, what type of switch was used? Seems like I remember it as a magnetic switch but maybe not.
Any help appreciated.
Discussion Which Seawind - 56" Flyzone with Retracts or 48" Dynam AND Flying Characteristics lvflyer Waterplanes 0 Sep 07, 2016 10:36 PM
Discussion Seawind 1st Outing Disaster - well almost robpretty Sailboats 21 Aug 14, 2016 10:00 PM
Discussion Seawind help seabee CE Sailboats 4 Aug 12, 2016 03:20 PM
Discussion Kyosho Seawind - Need 2 x 14mm screw! boatingbob Sailboats 5 Jul 23, 2016 10:59 PM
Help! Joysway Caribbean RTR RC Sailboat and Westward 18 RC sailboat manninge Sailboats 3 Apr 09, 2015 06:49 PM
