Whoops!
My 4S lipo is at 12v, can it be recovered?
I was out flying 4S on my quad and during flight and my battery alarm disconnected. When I landed I checked the voltage again and it was at 12.0v (3.05 - 2.72 - 3.07 - 3.16)
Start the charge again, I have run batts down to 2.9, 2,9,2.9,2.8 and they still go like the clappers, look for obvious signs of puffiness, heat, etc. If in doubt toss it.
Yes, good option.
If the cell voltage dropped while on charge, it is probably because it has an internal short. You try to put more voltage on it, it could burst in to flames. It might just do that anyway, on its own. I would discharge the pack completely, outside, attached to a 12V car lamp, and then dispose.
4V isn't it. A discharge LiPo will read near zero V. There is a minimum below which your quad's ESCs won't run, though. That's why you want to use something like a filament light to run the pack down. That will get it to zero Volts in 24 hours. Then you can throw it in the trash. Lithium batteries are safe for landfills and fully discharged they are not a fire hazard. |
A lipo pack with less than 30% capacity left in it is reported not to be a fire hazard. It will just get very hot if it does go into thermal run-away without any flames.
Looks like that is what could have happened to your pack. |
It is possible that it might come back. Instead of trying to charge it at very low voltage it is better to charge it as a 4S but at very low current like 50 to 100 ma.
If it does not have a dead cell then your chances are pretty good but keep a very close eye on it. If it gets hot or, if it will not charge beyond some voltage that is less than fully charged then get rid of it. |
Rise from the dead? I doubt it.
![]() He has already discharged it to less than 1V/cell. He has done what you suggested at a charge rate 0f 0.3A. See posts #3 and #5. (I know it's chore to read the whole thread sometimes....LOL) |
Thread Tools | |
Similar Threads | |||||
Question | How much continuous current can be drawn from 12v SLA AGM batteries? | Bird09 | Batteries and Chargers | 85 | Jul 17, 2019 12:37 AM |
Help! | Lipo Unbalanced Cell - Can it be recovered? | n4t3 | Batteries and Chargers | 7 | Oct 13, 2016 07:08 PM |
Help! | My 3s lipo is sitting at 2.4 volts per cell. Can it be saved? | logandm98 | Electric Power Cars | 13 | Aug 27, 2016 08:25 AM |
Help! | Can my 5V pan servo use the 0V of my 12V camera and VTx. | Tommygunn | Power Systems | 6 | Feb 06, 2016 01:10 PM |
Discussion | Can multiple lipo chargers be used at the same time on a 12v battery? | 22niner8juliet | Batteries and Chargers | 10 | Aug 07, 2010 11:20 PM |
