Jul 12, 2017, 05:17 PM
Just call me Justin.
Setting up an i2c port on a FC without an i2c port?
I have a naze32 rev6b thin board that does not have an i2c port/pads. The reg rev6b does, but nada for me. I would like to use an i2c device with inav. I have read in a couple spots that uarts will auto connect/configure i2c devices.. but just like an i2c port, I don't have a uart3...
So, can I use any uart? Softserial port? Do I have to do any cli commands? Also, sda to rx or tx?
Any help would be awesone, thank you
Jul 12, 2017, 05:29 PM
You have License ? Sure ...
rkovac14's Avatar
If its the Diatone Thin Naze32 Rev6b, it should have i2c as its based off regular naze32 rev6b ( http://www.dronetrest.com/uploads/db...657a292b5b.jpg ). I cannot find pinout of the diatone board anywhere but i guess it will be on the connector i circled
Jul 12, 2017, 05:31 PM
These are the pinouts..... No i2c.....
Jul 12, 2017, 05:36 PM
rkovac14's Avatar
My best guess is that U2TX and U2RX will be I2c
rkovac14's Avatar
its CH3 and CH4
Jul 12, 2017, 05:39 PM
cool. which one is sda scl? and do i need to setup anything in cleanflight? also, can i use softserial at the same time?
Jul 12, 2017, 05:46 PM
rkovac14's Avatar
SDA = TX Data SCL = RX Data. BTW it was just my educated guess and there is almost nothing about this board online. I am sure you can use softserial as it has nothing to do with i2c. I have never used cleanfilght (only betaflight) but i am sure you have to set it up first.
Jul 12, 2017, 05:50 PM
thank you so much....
Jul 12, 2017, 06:03 PM
rkovac14's Avatar
i just did a very quick research and it looks like it will autodetect MAG and BARO (if that's what you are connecting via I2C)
Jul 12, 2017, 08:01 PM
Very nice. Thank you. Now it's time for testing.
Question Apm just 1 telemetry port and 1 i2c port?!?! turborocket Multirotor Drone Electronics 4 Sep 29, 2016 09:37 AM
Question need help setting up spoilerons on an Allusive 2.2 motor12 Sailplane Talk 1 Dec 08, 2015 12:12 PM
Discussion Multiple I2C sensors on one FC port ewoodcox Multirotor Drone Electronics 2 Jan 14, 2015 04:37 PM
Discussion How to use an external BEC without losing a port on receiver? Whoopz Electric Plane Talk 5 Nov 05, 2011 05:17 AM
