Jul 11, 2017, 09:41 PM
New Product
Detrum D-CAM Brings You HD and Wide Vision
In outdoor sports and aerial photography applications, action cameras have gradually become an essential device for recording. D-CAM camera came into being, is lightweight and portable, and has the amazing performance of professional camera. It can make you have fun and enjoyable.
Small Size, good Appearance
The appearance is simple and smooth with ergonomic button structure, the small size (42mm*75mm*22mm) and light weight (with battery 62g, without battery 44g) make it very suitable for outdoor sports and FPV use.
Description: Name: In hand.jpg
Description:
Quad HD 2K
Provide 3 kinds of video resolution, the highest code rate can reach 24Mbps. Users can select Quad HD (2560*[email protected]) for high resolution, or select a high frame rate ([email protected], [email protected]) for smoother and more realistic video.
FPV Camera
The most popular application of D-CAM is carrying it on the aircraft for recording, connecting it to a video transmitter (such as Detrum DVT58). Then the video receiver and display device on the ground station can display the video sent from the D-CAM, to achieve FPV function.
Description:
Integrated OSD
D-CAM has integrated OSD function, then you can know the status of the camera in real time, such as battery level, video status, etc., It is convenient in FPV use.
Wide Angle Lens
With a 2.5mm lens, the angle of field is FOV150, which is wider than most of the cameras.
Name: fov 150_3.jpg
Description: Name: Wide angle.jpg
Description:
Very Simple to Use
You can take photos or recordings at any time without changing modes, it is very simple to use.
Low Power Consumption, Large Battery Capacity, Removable Battery
The D-CAM has a built-in 1050mAh battery, can carry out continuous recording for more than 90 minutes. Charging is very simple and you can start charging just by connecting the D-CAM USB port to the power supply without removing the battery. And the battery can be disassembled and replaced. Since then, there is no need to worry about running out of the battery.
Loop Recording
After this function is enabled, the recording process continues to record at the beginning, erasing the previously recorded material and replacing it with the content. The video segment length can be set.
USB Disk Mode
When switching to USB disk mode, you can access the SD card without removing the SD card, only by using a USB cable to connect the computer.
Support PWM Control, Take Photo/Recording Remotely
D-CAM outputs 2 PWM signals, you can use the cable included in the box to connect it to the receiver. Then you can take photo/recording remotely via the RC transmitter.
Name: pwm control_5.jpg
Description:
Support WiFi
With the self-developed APP, allows you to connect the camera via a mobile device for live preview, parameters settings (image quality, white balance, resolution, exposure, etc.), recording, photo shooting, sharing photo/recording to networks, etc.
The camera can be controlled from a distance to take photos and videos through the APP, and the distance can reach 30 meters without interference.
Currently only Android APP is supported.
Description:
Suitable for a Variety of Scenarios
Mounted on the multi-rotors and airplanes
Mounted on the cars
In outdoor sports, tied it to arms and bicycles for shooting
Used as a driving recorder
Description:
Specifications
Sensor : 4 megapixels, 2umx2um
Angle of Field: FOV 150
Encode Format: JPG, H.264
Video Resolution: 2560*[email protected], [email protected], [email protected]
Video Files: MP4
Audio: Stereo, [email protected]
TV Output: PAL/NTSC
SD Card: FAT32/exFat, max Micro SD Card supported is 64G (need class 10 or above)
Interface: Micro USB
WiFi: 2.4G
Battery Capacity: 1050mAh, continuous recording for more than 90 minutes
Dimension: 75mm*42mm*22mm(L*H*W)
Weight: 62g (with battery) /44g (without battery)
For more about Detrum Action Camera, please click this website below:
http://www.dynam-rc.cn/Product/view/id/697.html
Detrum Action Camera on Facebook:
https://www.facebook.com/dynamhobby/...61802387490669
Detrum Dynam Own column on RCG:
https://www.rcgroups.com/detrumtech-1000/
Jul 12, 2017, 03:35 PM
Custom User Title!
Very interesting. Looks like a great camera. Care to answer a few questions?
expected price?
available when?
included accessories / mounting options?
sensor model?
h.265 only, or h.264 setting as well?
bitrates?
field of view options (narrow/medium sensor crop)
review samples?
Thank you. Looking forward to this camera!
Jul 12, 2017, 08:00 PM
→ 404 Not Found
Justapoke's Avatar
Nice to see Dynam in the cam market. Will be interesting to see how this develops.
Also love the new B-26 Marauder
Discussion Hawkeye 6Q 4K action camera *smallest 4K action cam for quads* Quadbuddy Mini Multirotor Drones 13 Jul 12, 2017 08:08 AM
Discussion Anyone used this cam? "gnarly HD 1080p Sports Action Camera" crashtested FPV Talk 4 Nov 05, 2011 06:37 AM
