Turnigy TZ4 AWD Micro Touring Car V3 Drift Edition - RC Groups
The re-designed TZ4 AWD comes with a laundry list of performance parts and upgrades! Let's take a quick look at this miniature drift chassis.
The Turnigy TZ4 AWD Micro Touring Car V3 Drift Edition
Drift Across the Kitchen Floor
Based on the MINI-Q chassis, this pint-sized drifter features a shaft-driven AWD setup, carbon fiber chassis, a 130-sized brushed motor, a 400mAh LiPo, and is fully compatible with Kyosho Mini-Z bodies and wheels/tires. The Turnigy TZ4 AWD Micro Touring Car V3 Drift Edition retails for $65.98 and requires a HobbyKing GT2B or GT2 transmitter.
Here's what Hobbyking has to say about the TZ4: Turnigy TZ4 AWD 1/28 Mini Touring Car Ver.3 Drift Edition is a mini size RC drifter with a big guy attitude…The Ver.3 is based on the latest MINI-Q chassis and has all the features of its bigger 1/10 scale brothers from tunable suspension and chassis set up to swappable Lexan bodies and adjustable wheelbase. Perfect for drifting around the kitchen floor on rainy days or clear your desk at work and test your skills by not letting it fall off the edge or letting the boss catch you.
Performance is unprecedented for its size with shaft drive AWD and front and rear solid diffs, full ball bearings and Carbon chassis. The 2 cell 400mAh LiPoly Battery provides ample run time. The upgraded PCB and 3 wire servo give the TZ4 AWD much faster and smoother response on steering and throttle and there is a full list of hop-up and replacement parts, and with the removable body posts and adjustable wheel base chassis the Turnigy TZ4 AWD is Compatible with a host of Kyosho Mini-Z body shells wheels and tires!
The Ver.3 has an extended wheelbase of 100mm compared to the Ver.2 which was 94mm, this extra 6mm makes the car a lot easier to handle in a drift and allows for much more consistent arcs and more controlled and precise changes of direction, in other words you won't spin out quite so easily. Because it is based on the Mini-Q chassis it is very easy to use the hard plastic shells from the Mini-Q or Kyosho Mini-Z. It can also be fitted using the concealed fixings of the Mini-Q by removing the body posts and adding the Mini-Q front body mount. You just need a HobbyKing GT2 or GT2-B radio to “Bind and Drive” the TZ4 AWD, and commandeer a room, or desk, to hone your indoor Tokyo Drift skills!!!
CLICK HERE for more information on the new Turnigy TZ4 AWD Micro Touring Car V3 Drift Edition
Jul 11, 2017, 07:08 PM
looks good but what is with that wheel offset.. at least fill the guards :S
Jul 16, 2017, 08:33 PM
One of the best things about this platform is that the Rx is Flysky. Almost all of us car collectors have a FS radio, and if not it's a cheap worthwhile addition.
Jul 17, 2017, 12:11 PM
Habanero's Avatar
The most challenging thing about drifting for me is finding a suitable venue/location. This possibly could turn any garage into one- if you move your car in the meantime lol.
Discussion Turnigy TZ4 AWD 1/28 Mini Touring Car shahram72 Micro Cars 283 Mar 24, 2018 12:46 PM
Discussion Mini-Q Sport 1:28 RC AWD Touring Car Rock Crawler Micro Cars 9 May 24, 2017 11:54 PM
Mini-Review 3Racing Sakura D4 AWD Drift Car DutchRC On-road Cars 0 Jan 12, 2016 12:52 PM
Discussion Questions on Touring Cars and Drift Cars dwlee Car Talk 36 Jul 16, 2008 01:18 PM
