Oct 24, 2017, 12:28 AM
I want to fly everything!
Lance Nordby's Avatar
No responses?
I feel like Boris Karloff as Frankenstein's monster. "She..hate me!"
Ehh! Ehh!
Oct 25, 2017, 10:30 AM
So many planes, So little time
Xflyfun's Avatar
3. Must use FT "tiny Trainer" fuselage and power pod at stock length made of FT waterproof foamboard or DTFB.
4.Any wing or tail profile or configuration is allowed. Any Prop is allowed, any covering is allowed. Developments of aerodynamic efficiency, exploring limits of "clipping" and different aerodynamic "cheats" are encouraged within these limits.
Just build the stock tiny trainer fuselage and cut the wings and tail down to suit your likes, Boris
AMainHobbies is selling the Quick kits, shipping from California.
Pushrods seem to be .039-.040 as far as the Harbor freight caliper is concerned.
I've got 600 cinder blocks to stack up for pylons, yea, don't worry- I'm painting them orange so you can see them.
Nov 13, 2017, 10:52 AM
Xflyfun's Avatar
Unlimited, P-51 ?
So I'm real lazy nowadays and just order Quick kits from AMainHobbies.
While I was shopping for my latest rebuild Tiny Trainer.
I happened to see these and wonder, could we look at these little guys....?
Name: small racers.JPG
Description:
They're mighty minis! and only $18.00 or $30.00 for the two pack.
Nov 14, 2017, 11:04 AM
Been a while!!
Hi Guys,
I've been remiss in tending to this thread.
Lance, I think gear would be great, but will probably slow them down. I was going to try an in-the-fuselage gear that would only be protruding about .75" to clear the prop, but I wouldn't sanction any thing you liked to try. Again, you can add anything you want!
We've found there is little you can do to speed these up but almost anything you do will slow them down. Even my fairings and turtleback make them slower. I'm encouraging all wing and tail and planform mods. The only real guideline is to start with the TT fuselage (and wings as a start but you can cut them up) Mainly so that the average devotee can buy the TT and build from those parts. We've tried clips of 50% which makes them fly pretty badly and launch scary, but not any faster and about four different planforms and all three tail designs. My personal preference for durability and general handling is the "T" configuration, but the fastest is probably the "V" but it doesn't turn in as well.
I have a few "no sidethrust" firewalls for you. I've been flying these so I can run all the props including CCW.
I can't wait to see "Your Stank"
Frank,
The Mighty Mini fighters are smaller heavier and harder to build, and possibly not as durable due to the wing design and I'm suspicious that they don't fly quite as well or are as forgiving, but you are always welcome at least until we get really serious. Heck, I've been flying the super bee and the bronco with the crowd of two buck racers when mine are out of commission so anything you want to put in the air with us is just more excitement and fun. I wanted to encourage modification and development of a basic design and the trainer just made it easier to try different tails, wings and planforms than the fighters.
If we do get serious about this ( I have a scheme for actually keeping track of laps/cuts that is easy) I would want to mainly retain the 1803 and 12A esc as the basic Formula, but if people want to migrate to the Tiny fighters that would not be the end of the world. I also want to do an "unlimited" class allowing 1803's with different KV and four cell or maybe even larger motors, but the main thing is limiting the cost ceiling.
I built my fourth one last week so I now have a vee and a tee and I'm still on my original two power systems with maybe 60 flights each on them.
Nov 14, 2017, 11:24 AM
I got Chris confused with "Rocket foamy Frank" ...mIghty mini response was meant for X-FLY-FUN.
I'm bad with aliases...You can seee how mystic and clever mine is
Nov 23, 2017, 01:39 PM
I think your alias shows you have the 'nads to put up your actual name!
I really like the power system you have come up with is perfect. It's really cheap and they seem to go fast with good duration. Plus, I have a whole bunch of batteries that are the right size and that appeals to my sense of cheapness.
As a bystander watching you guys fly those things, it looks like too much fun to pass up. The planes are "just right" for the job. Cheap and fast, with low emotional attachment.
I made a turtledeck, but now I might leave it off after your comments.
I'm wondering if the fuselage could be simplified so there aren't so many fiddly parts. Just make it all one piece. It could be lighter and more aerodynamic as well. What do you think Joe. Or is it worth it so you can replace just the nose after a crash?
Another thing, Joe. For some reason the link in the email notices to this thread doesn't take you to this thread but instead it goes to the thread index.
P.S. I got a turbine engine and an Usher F-106 last Saturday!
Nov 27, 2017, 06:15 PM
Turbine-powered cardboard pylon racer - what could go wrong?
Nov 28, 2017, 03:37 PM
burkefj's Avatar
Wait, did somebody mention rockets????
Nov 28, 2017, 08:41 PM
Yes, pylon racing r/c rockets. Now that would be something.
Dec 04, 2017, 04:54 PM
I've been reading this, and I'm going to try to join in the fun. I've got a bunch of electronics and will have some good build sessions over the holidays.
Question on the wing: can other materials other than foam be used in the wing? Specifically, is a CF spar an option, or would that push it into the unlimited class? The fuselage rules are very clear (DTFB), but the wing rules aren't that explicit.
Dec 15, 2017, 12:23 AM
Classification and rules ...heh!
The more I think about it and the more I've flown these, ( probably a hundred flights and five airplanes) I'm almost convinced that you really can't get much out of the little 1806 motor than we are getting regardless of the airframe...which is , in a way, good!
Tiny wings with razor trailing edges and all sorts of props and fairings might add 5mph over a stocker built to the original plans I posted. The more modified ones, however become more challenging to fly, don't turn as well and launch with sometimes disastrous hilarity.
This gets me thinking about classification.
I'm leaning toward specifying the basic rear tiny trainer fuselage as a guideline for stock class and limiting the motor to an 1806 (2280 or 2300KV whichever is cheaper on banggood that week) And leaving the remainder up to the designer/pilot as long as the majority of the airframe is DTFB of some sort. There has been some discussion of the benefit of the rubber band wing and the swappable forward fuselage which really enhance the survive-ability of the planes, and I think we could relax the rules to allow fuselages of any design conforming to the basic profile of the TT, and of course, any wing you are brave enough to launch!(made of DTFB). Internal titanium spars are O.K.
The whole reason for the classification rules was to limit cost so it wouldn't become expensive to win and to assure that everyone if they wished could be relatively competitive cutting some material off of a tiny trainer quick-build kit, and still have a chance.
After seeing Chris's Mini mustang fly last weekend, I'm thinking of making the "unlimited" class open to the 2205 motor as well as the 1806 (including twins) with any (primarily) DTFB or flite test foam airframe. I'd love to see a bunch of mustangs, corsairs and sea furies racing around for under $50 each!! I do believe that a stock clipped tiny trainer might go around a two pylon course as fast or faster due to the ability to make blindingly fast 180 degree turns, and I don't think the mustang was significantly faster than the original Racer-T on 3S.
So:
Stock class:
TT fuselage profile (swappable or not, wings removable or not)
foamboard construction with whatever plastic or paper fairings you think will make it faster (but will not)
1806 motor (single or twin) and 12A ESC
3S 860 MAh battery max
Unlimited class:
Foamboard construction (primarily, with added strengthening or streamlining of other materials such as 3D printed parts or carbon rods or infused boron fiber spars)
1806 motor single or twin
2205 single engines
4S max of any MAh
But remember...there are "claims " values for anyone that wins...so if you want to keep your $200 airplane , you'd better not win!
UNlimited class
Dec 15, 2017, 12:28 AM
The Usher 106
I'm glad you got this plane Lance,
You saved me from needing to store it! It could be a real beauty!
Dec 15, 2017, 04:26 PM
Xflyfun's Avatar
Can't tell them apart
Description:
The tiny Mustang has a rather small battery area.
When I build the next one, I might cut out a notch in the leading edge, wing center, for battery.
Dec 15, 2017, 08:20 PM
Chris, is that Mustang a 2 buck racer? Looks like it.
I still have an image burned in my mind of you walking down the driveway carrying that green wing back to your truck last Sunday. You looked so sad it brought a tear to my eye.
I got over it eventually.
Joe, the main portion of the F-106 fuselage is setting vertically on my nightstand.
Dec 15, 2017, 11:01 PM
Xflyfun's Avatar
Parts added to green wing
Name: added parts to m6a wing.jpg
Description:
Name: M6a almost ready.jpg
Description:
I have to paint the floats
Wait for the ice to melt
Drag the beaver lodge out of the pond
Help! X-Racer F303 V3 won't connect to Betaflight 19Gerhard85 Multirotor Drone Electronics 1 Nov 12, 2016 04:12 PM
Question X-Racer F303 flashed with βF but won't connect to CF thomas_rs Multirotor Drone Electronics 3 Jun 30, 2016 12:27 AM
Discussion Merits of X-tail V T-tail V V-tail for visibility flyonline Slope 16 Mar 01, 2008 08:27 AM
