Optima 6 Lite antenna fixx? - RC Groups
Jul 10, 2017, 09:58 AM
Gravity sucks.
mrittinger's Avatar
Question
Is it possible to have an antenna reattached on an Optima 6 Lite? Was torn off in a crash....
Thx,
Mark Rittinger
Jul 10, 2017, 10:36 AM
All Thumbs
Ranald's Avatar
Optima Replacement Antenna
Thx,
Mark Rittinger
http://www.weekenderwarehouse.com/op...tenna-set-x-2/
BODA type.
Jul 10, 2017, 12:10 PM
Found this image. Looks like the BODA snaps right onto the main board after you open the case. Sounds like you had an extremely hard crash.
You could have damaged the other receiver parts besides the antenna you should test it very well before you fly again, or replace the whole unit if it doesn't pass. Ask Hitec what they think.
Jul 10, 2017, 12:15 PM
Gravity sucks.
mrittinger's Avatar
They do, just need correct antenna.
Jul 11, 2017, 04:01 PM
Xpress..'s Avatar
The BODA antenna offered on our website is the only BODA antenna available for Hitec receivers. They just clip on.
Jul 11, 2017, 04:41 PM
Gravity sucks.
mrittinger's Avatar
The weekender wedsite?
Thermal, yes, I thoroughly check rx before use.
Jul 12, 2017, 08:08 PM
All Thumbs
Ranald's Avatar
Hi, yes, Weekender is Hitec's site. The BODA antenna there is OEM. I used them to replace my busted Optima 9 antenna. They even came w/ the rubber grommet to prevent case-edge abrasion (and to toughen the cable against undesired tugs on the board?)
Cheers!
Jul 13, 2017, 12:58 PM
Xpress..'s Avatar
This is correct, the Weekender Warehouse name was created as a direct purchasing outlet- everything purchased through Weekender Warehouse comes directly from us, it is not a 3rd part vendor.
Please see the following thread:
https://www.rcgroups.com/forums/show...nder-Warehouse
Discussion New Hitec Optima 6 LITE MikeMayberry Radios 107 Mar 02, 2015 11:50 AM
Discussion Optima 6 or Minima 6 2.4 Antenna Installation Ron Kay Hitec/Multiplex USA 3 Nov 16, 2011 10:00 PM
Help! Hitec OPTIMA 6 LITE hi flyer Radios 5 Sep 26, 2011 07:43 PM
Help! A9 and Hitec Optima 6 lite Low voltage warning roadhogtri Radios 6 May 16, 2011 10:42 PM
