Lift of a Rigid Airship - RC Groups
Jul 05, 2017, 08:03 PM
Hello, I have designed a balsa zeppelin based on the USS Akron/Macon designs, without electric stuff and rudders it has a static lift of 197 grams with Helium and 257 grams with Hydrogen, and I was wondering, how much static lift is needed to lift a model off the ground? Does it just need at least 1 gram of lift or does it need 200? (Also I didn't see a rigid airship forum, hopefully this works)
Jul 06, 2017, 02:13 AM
Melbourne, Australia
Hi Crayex,
1 gram will do just fine... in fact, if you want level flight, you'll need to ballast it so that it has roughly 0 grams lift!
However I've found a host of factors such as temperature, pressure and humidity will effect the lift on any particular day, possibly by as much as +/- 5% - so it's good to design in a margin :-).
- Chris
Discussion Variable Buoyancy Rigid Airship Street racer Blimps 0 Dec 10, 2016 12:33 PM
Build Log 10' rigid airship frame capricorn Blimps 144 Jan 23, 2010 11:08 AM
Question Interested in RC rigid airship Snookr Blimps 5 Nov 20, 2009 07:03 AM
Question Foam Rigid Airship WillowPtarmigan Blimps 16 May 15, 2008 08:37 PM
Question 10 Foot rigid outdoor airship? GamecockAirship Blimps 13 Jan 14, 2006 09:43 AM
