Jul 05, 2017, 12:12 PM
electric power,what else!
eJets's Avatar
Build Log
AeroPlusRC Zivko Edge 540 V3 92"/60cc
Hi Folks,
Today was christmas and easter the same day.... got my AeroPlusRC Zivko Edge 540 V3 92"/60cc and will report my build progress....
Manufacturer Page: http://www.aeroplusrc.com/page117?pr...ct_category=34
stay tuned
Markus
Jul 05, 2017, 12:18 PM
eJets's Avatar
Unpacking
....well and safe packing. unpacking brings a very good manufactured kit to day light - no wrinkles at all never had this before....
Jul 05, 2017, 12:34 PM
eJets's Avatar
Kit Weight
Here is an overview of the part list and coresponding weights:
- Fuselage incl. Canopy 1765g
- Motor Cowling 388g
- Gear 159g
- both Tire Coverings 70g
- left Wing 728g
- right Wing 728g
- left Stabilizer 168g
- right Stabilizer 165g
- Rudder 122g
- Spinner 95g
- Accessory (incl. Wheels) 298g
- Wing Bar 140g
- Stabilizer Bar 17g
TOTAL: 4843g / 170.83oz - an impressive light weight kit!
Additional Material for smoker only:
- Fuel Tank 75g
- add wood parts (e.g. for silencer) 149g
I am optimistic to stay below 8kg AUW with a 12s setup
Jul 05, 2017, 01:38 PM
eJets's Avatar
planed 12s Setup
some prelimenary calculations with www.eCalc.ch looks promissing:
12s 4300mAh-30C
Castle Edge 120HV
Leomotion LEO8015-180
Prop 22x12 or 23x10 or 24x8
Deep Link of Calculation: https://ecalc.ch/motorcalc.php?ecalc...V3%20-%2092%22
Jul 06, 2017, 02:43 PM
eJets's Avatar
Pilot «Peter» - 7g
Pilot «Peter» is ready and puts pressure on me to get that airplane finished for the next race....
Made of 2 mirrored pictured printed on photo paper results in a super light weight pilot of 7g only.
It looks great from distance - I do not like gost planes
Jul 08, 2017, 03:51 AM
eJets's Avatar
Elevator
...finishing the elevator using 1.75"/45mm Miracle arms and Futaba BLS471 Servos (13.kg*cm / 191oz*in @7.4V)
using a quite light servo (57g/2oz) to avoid getting tail heavy at the end....
I used the Control Surface Moments Excel from eCalc.ch to evaluate the required torque
Jul 09, 2017, 03:18 AM
eJets's Avatar
Tail Wheel
The tail wheel assembly is easy, BUT....
CAUTION: Do not overtorque the aluminum screw that will hold the tail gear shaft - it will break
therefore I had to modify the assembly and will try how it works. otherwise I'll have to builde a new screw....
Jul 09, 2017, 06:40 AM
eJets's Avatar
Main Gear
for the main gear assembly I used for the wheel pants 4 outer wood spacer and one inner spacer in order to center the wheel.
Jul 09, 2017, 08:20 AM
eJets's Avatar
Aileron
finishing the wings using Futaba BLS175 (21kg*cm/291oz*inch @7.4V) with 20cm/8" cable extension and a 45mm/1.75" Miracle servo arm.
I love the cable holder at the wing root.....
Jul 10, 2017, 12:46 PM
eJets's Avatar
mounting motor
using a Dualsky GA4000.7 from www.leomotion.com, with a Fiala 20x12 prop.
for the installation of the motor 90mm spacer are required. due the squared holes in the firewall a 45 or 90 degrees drilling is too close and would weaken the firewall - therefore I went for a "asymetric" drill-scheme...
Jul 10, 2017, 12:52 PM
eJets's Avatar
forced cooling
for the motor I added a forced cooling to the lower center hole of the motor hud by using a 90 degree drain pipe (weight 22g) from the plumbing accessories
Jul 11, 2017, 05:55 AM
jkent27's Avatar
...deleted
Jul 11, 2017, 01:37 PM
eJets's Avatar
Rudder
the rudder horns need some sanding not only to fit the mount but also to bring the pull-pull fix points in line with the hinges.
Jul 11, 2017, 02:08 PM
eJets's Avatar
RC Receiver and Hub
I am using a Futaba R6303SB in combination with a Dualsky S.BUS HUB 18. The hub is supplyed by a Castle BEC Pro, is rated for 20A.
there is plenty of space to acomodate the battery to fire-up my Edge....
Jul 11, 2017, 02:32 PM
eJets's Avatar
first run-up
soldering the plugs to the Castle Edge 120 HV and mounting to the motor spacer. the JETI anti-spark plug does avoid sparks when plug-in the battery.
for forced cooling the cowling airstream will be directed over the ESC and BEC entering the fuselage only though the motor dome, over the batteries and overboard throug an additional vent hole behind the rudder servo (not open yet...)
the short run-up of the Dualsky GA4000.7 (Leomotion LEO 8015-180) is successfull.
Discussion ZIVKO Edge 540 larrylb7 3D Flying 1 Sep 01, 2017 06:16 PM
Discussion Pilot-RC Edge 540 V3 92"/31% eJets Giant Electric Planes 0 Jun 26, 2017 01:57 PM
Discussion 92" Edge 540 Red/Yellow/Black/White bobbyleepritch Giant Scale Airplanes 0 Nov 28, 2016 08:56 AM
Discussion Zivko Edge 540 Scale drawing bigandy Scale Kit/Scratch Built 0 Jun 12, 2006 02:16 PM
