Jul 04, 2017, 05:03 AM
New Product
ZOHD Nano Talon 860mm, ZOHD Orbit Wing & ZOHD Dart Sweepforward Wing 635mm
Update: A new model with a swept-forward wing design has been added: the ZOHD Dart(PNP)
PNP ZOHD Dart Sweepforward Wing 635mmhttps://www.banggood.com/ZOHD-Dart-Sweepforward-Wing-635mm-Wingspan-FPV-EPP-Racing-Wing-RC-Airplane-PNP-p-1201283.html
PNP ZOHD Nano Talon 860mm: https://www.banggood.com/ZOHD-Nano-Talon-860mm-Wingspan-AIO-HD-V-Tail-EPP-FPV-RC-Airplane-PNP-With-Gyro-p-1168297.html
FPV (with Runcam Split like camera and VTX) ZOHD Nano Talon 860mm:https://www.banggood.com/ZOHD-Nano-Talon-860mm-Wingspan-AIO-HD-V-Tail-EPP-FPV-RC-Airplane-PNP-With-FPV-System-p-1168298.html
PNP ZOHD Orbit 900mm Wing: https://www.banggood.com/ZOHD-Orbit-900mm-EPP-AIO-HD-FPV-Flying-Wing-RC-Airplane-PNP-With-Gyro-p-1168299.html
FPV (with Runcam Split like camera and VTX) ZOHD Orbit 900mm Wing: https://www.banggood.com/ZOHD-Orbit-900mm-EPP-AIO-HD-FPV-Flying-Wing-RC-Airplane-PNP-With-FPV-System-p-1168296.html
ZOHD Nano Talon Details
This 860mm Wingspan Nano Talon is a portable edition of the Talon Airframe series. The pre-installed AIO HD camera and 5.8Ghz Vtx brings you an integrated solution for FPV flying. It is super easy to hand-launch and fly because of the gyro, This Nano Talon is very convenient to carry with because the detachable mainwing and tail wing can be detached easily by plugs and magnets. The built-in servo structure makes the airfoil more aerodynamic, and avoid damage even in a crash. The inside room and extra bottom hatch are also huge for more FPV gear.
Description:
Brand Name: ZOHD
Item Name: Nano Talon
Wingspan: 860mm/33.85in
Length: 570mm/22.44in
Flying Weight: 361g(w/o FPV gear)
Material: Crash Resistable EPP
CG: 3.5cm from the wing leading edge(mark under the wing)
Color: White + Black
Motor: ZOHD 2204 1870KV BL
Motor Shaft Diameter: 5mm
ESC: 30A W/1A BEC(XT30 connector)
Servos: 2pcs 8g digital servo
Propeller: 6x3
Recommended Battery: 3S 1300-2200mAh 25C XT30 connector
Recommend Radio: ≥6CH Click here
Flying speed: 12 to 90km/h
Features:
* Built-in Gyro make the Nano Talon flys super stable, and easy to control.
* Autonomous fly directly after hand-launch, never crash when take-off.
* EPP molded wing, pre-built-in Carbon Fiber spar for enhancement, light and flexible plus crash resistence.
* Detachable mainwing and tailwing for easy transport, and easy to change wing by simple plug.
* Mainwing connected to fuselage by buckle, will be disconnect and release during crash.
* Pre-installed 1080p/30fps HD Camera, recording and 5.8Ghz FPV at the same time.
* “NACA”air-intake in nose and air-outlet in tail for better cooling on FPV gear.
* Extra rooms in canopy and cabin for FPV gear, bottom hatch provide bonus rooms for more FPV equipment
* Self tighten prop nuts for secure prop mounting
Pre-installed FPV gear:
Full HD AIO Camera
1. 1080p/30fps 12megapixels
2. Full HD 1080p/30fps recording, up to 64G Micro SD Card
3. On Screen Display of battery capacity
4. Auto Save Video when landing
5. FOV(Angle of Field): 120°
6. WDR(wide dynamic range): ON
7. Video Files: MP4
8. Interface: Micro USB port
9. Supper WDR FPV image with low latancy
10. FPV video: 720*480 30FPS
11. Operating Voltage: 6~25V
12. With Microphone for clear sound recording
12. Size: 27.2*27.2*32.5mm
13. Weight: 16g
Video Transmitter
1. Power: 600mW
2. Frequency: 5.8Ghz 40CH w/ Race Band
3. Operating Voltage: 6~25V
4. 5.8GHz 3 leaf Clover LHCP Antenna
5. Size: 32.5*24.3*9.4mm
6. Weight: 13g
ZOHD Orbit Wing Details
This 900mm Orbit Wing is a snap-n-fly AIO portable HD FPV wing, the pre-installed AIO HD camera and 5.8Ghz Vtx brings you an integrated solution for FPV flying. It is super easy to hand-launch and fly because of the pre-installed gyro, The Orbit Wing is very convenient to carry with because the detachable mainwing can be detached easily by plugs. The built-in servo structure makes the airfoil more aerodynamic, and avoid damage even in a crash. The inside room are also huge for extra FPV gear.
Description:
Brand Name: ZOHD
Item Name: Orbit Wing
Wingspan: 900mm/35.43in
Length: 422mm/16.61in
Flying Weight: 455g(w/o FPV gear)
CG: 11.50cm from the wing leading edge(a bump CG mark under the wing)
Propeller: 6x3
Recommended Battery: 3S 1300-2200mAh 25C XT30 Plug
Flying speed: 10 to 85km/h
Features:
* Built-in Gyro make the Orbit wing flys super stable, and easy to control.
* Multiple bonus camera mount, compatible for Gopro H3/H4, Runcam2 HD, Foxeer HS1177 FPV camera in the market.
* Detachable mainwing for easy transport, and easy to change wing by simple plug.
* Pre-installed 1080p/30fps HD Camera, recording and FPV at the same time.
* More room inside fuselage for FPV gear
* “NACA” air-intake in nose and air-outlet in tail for better cooling on FPV gear.
* Self tighten prop nuts for secure prop mounting[/SIZE]
[SIZE="4]ZOHD Dart Sweepforward Wing[/SIZE]
This Dart Sweepforward wing is the first Subter-250g fixed wing that made by EPP mateiral. Detachable main wing and twin-tail wing makes the Dart Wing very easy to install and carry for out door flying, what’s more, the wings will disconnected during a crash, thus to protect the main wing and tail wing. You can put a lot of FPV gear and big battery inside the spacious hatch with “NACA” air-inlet. The aileron were enhanced by carbon strips to avoid any flex during flying and enable a precise control.
Description:
Brand Name: ZOHD
Item Name: Dart Sweepforward Wing
Wingspan: 635mm(25")
Length: 406mm(16")
Flying speed: 15km/h - 80+km/h
Motor: 1806 2000kv
ESC: 12A
Servo: 2pcs 4.3g Digital Servo
Propeller: 6x3
PNP Weight: 145g(0.31lb)
Features:
* Innovative Sweepforward wing design with large wing size and twin tail wing, avoid stalling during flying.
* Classical and practical “S” high efficiency airfoil, create powerful elevating force.
* Lightweight but durable EPP molded wing and fuselage, enhanced by built in carbon fiber spars, durable and super crash resistance.
* Detachable wing and tail wing structure, compact size, portable and easy to carry for out door FPV fly. “No-glue” required assembly, open box and fly in few seconds.
* Built-in Gyro make the Dart wing fly super stable, and easy to control.
* Spacious equipment bay for more FPV gear.
* With plastic cover to protect the fuselage bottom from landing scratch
* With bump for “CG” mark under the main wing.
* With "NACA" Air inlet and outlet for FPV gear cooling
Jul 04, 2017, 05:39 AM
nano...!! its will be fun lol
Jul 04, 2017, 05:49 AM
Fly,crash,glue,repeat!
Jake Bullit's Avatar
Jul 04, 2017, 05:50 AM
Originally Posted by Jake Bullit
Need testers?
Jul 04, 2017, 05:58 AM
I guess it's only a 3 channel though with only 2 servos and no rudder
Jul 04, 2017, 05:59 AM
http://der-frickler.net
(Jo)Hannes's Avatar
Would be great to get them without the electronics as well!
Jul 04, 2017, 09:39 AM
smoothvirus's Avatar
A little birdie told me RMRC will be stocking these in the USA. It ships as a 3 channel but you can add ailerons.
Jul 04, 2017, 09:51 AM
What FC is there going to be?
OSD?
Jul 04, 2017, 10:00 AM
paultbg's Avatar
Awfull images
The factory / BG really need to fire their photographer together with his mobile... The blue pictures are awful !
Message to the manufacturer: send me one of each kits and I will take for you some professional studio pictures ! NO joking!
Jul 04, 2017, 03:33 PM
I wonder what weight battery they're using to achieve the listed flying weight. A 3s 18650 pack could be very interesting in it
Jul 04, 2017, 07:54 PM
The shots are really bad, they hardly show anything at all.
Jul 05, 2017, 01:53 AM
The PNP version of the Nano Talon is now up for preorder for only $100 ($10 off)
Are you sure it's not the rudder that's missing? From one of the images, it looks like a single servo manages the tail and another the ailerons.
Jul 05, 2017, 03:13 AM
hally1983's Avatar
Looks to me like it has Ailerons as the center servo handles these?
Jul 05, 2017, 05:28 AM
0800howsmyflying
Captan Crash's Avatar
Hally, off topic I know but how's your goblin???
Jul 05, 2017, 07:44 AM
It looks like it has some dihedral or polyhedral. I wonder if they'll release a wing set for ailerons
New Product [New Arrival]Reptile S800 V2 SKY SHADOW 820mm Wingspan FPV Flying Wing RC Airplane BG Tobey FPV Aircraft 671 Aug 13, 2019 04:46 AM
New Product Spirit 600mm Wingspan EPP FPV Racer Flying Wing RC Airplane KIT BG Tobey Flying Wings 143 Jul 12, 2019 09:44 AM
Discussion DW HOBBY Thunderbird 700mm Wingspan V Tailed Training Parkfly RC Airplane KIT DWHobby Drra Foamies (Kits) 2 Feb 08, 2017 05:41 AM
New Product DW HOBBY Rainbow Ⅱ Flying Wing 1000mm Wingspan EPP FPV RC Airplane KIT - $28 lmpuIse Flying Wings 5 Dec 10, 2016 01:06 AM
New Product Flying Tigers P40EP Balsa Wood 860mm Wingspan RC Airplane KIT Drra Balsa Builders 2 Sep 12, 2016 12:27 PM
