This thread is privately moderated by VicT, who may elect to delete unwanted replies.
Jul 03, 2017, 01:37 AM
Pandora gear for Apprentice protects the prop
Main gear still protecting prop
The Pandora main landing gear can be pushed into the Apprentice front float gear slot just like the stock Apprentice gear. However the Pandora leg wire diameter is larger and stronger and offers better protection against prop strikes during taxiing, takeoff, and roll out. Of course if you don't flare and drive her in with a nose down 10-20 pitch then the stock 11/8 prop will probably hit and then inspection for damage is recommended before further flying.
The Pandora wire and wheels can be "plugged in" either swept forward or aft if the wheel pants are not installed. Most of my clubmembers prefer the pants and wire leg fairings so I use vice and vice grips to twist the axle area so the wheel pants are parallel to the fuse centerline. The plastic parts add very little weight but reduce drag and look attractive with trim covering. Here are two versions . The chrome legs are swept forward and the red legs are swept aft. I think the aft swept gear minimizes ground looping and looks more realistic.
Question Frames with integrated prop protection? Calienteboots Scratchbuilt Multirotor Drones 6 Jan 11, 2018 03:44 AM
Mini-HowTo freewing pandora nose gear board repair duffernut Beginner Training Area (Aircraft-Electric) 4 Oct 20, 2014 08:44 AM
Discussion Frame Experts: Total protection for prop frame Morphin Multirotor Drone Talk 9 Dec 29, 2011 04:11 PM
