This thread is privately moderated by eagle60, who may elect to delete unwanted replies.
Jul 03, 2017, 01:12 AM
eagle60's Avatar
Speed estimation with Doppler effect.
First you need a sound file of your flight. Remember that the closer the pass to the microphone the more precise will the estimation be. If the passes are too far from the microphone the frequency analysis (and therefore the speed result) will not be real.
Second you need a spectrogram progam, which can be downloaded from internet, but you can also find as app for android in the playstore. With this program you will see graphically (and read) the incoming (higher) and outgoing (lower) frequencies (remember that the more preccise the reads will be the more real the result will be).
Third you need to calculate the sound speed, which depends on local temperature (C) and humidity (%) of the moment (this latter is not much effective and could be ignored, but temperature is important as it could change results significantly), but this is included in the datasheet supplied herebelow. I suggest to separate the single passes audio and produce multiple frequency readings in order to have more speed computing which can give an idea of your model speed (input data are to be placed in the orange columns).
Hope this will be helpful for all those that do not want to put a gps data logger on the plane.
Finally remember that all the apps using Doppler effect to compute the speed of your model ignore the humidity datum and get the local temperature datum from the meteo system, that is why they require the gps to be on, therefore they can not be used on a second moment. If they do not ask the gps to be on do not trust their results.
Discussion E197 Wing Cruise and Landing Speed Estimate Please JimHSoars Modeling Science 7 May 02, 2016 06:24 PM
Discussion Can someone tell me the speed of my Pogo with a Doppler program? cherrybomb48 High Performance 1 Aug 11, 2013 04:25 AM
Discussion estimated top speeds with this airframe? walkingonair69 Foamy EDFs 3 Feb 15, 2010 09:03 AM
Discussion Estimating Wind Speed With Ribbon rckowal Electric Plane Talk 15 Jul 25, 2009 07:10 PM
Calculating speed with doppler effect Xoltri Electric Plane Talk 4 Mar 16, 2003 10:23 PM
