Jul 27, 2017, 01:24 PM
Even cheaper - arduino nano based solution
https://sites.google.com/site/foamcuttercnc/electronics
modified GRBL 0.9j and GRBL controller for 4 axis foam cutter (including H-bot machine)
https://sites.google.com/site/foamcuttercnc/software
Hot wire CNC firmware test (1 min 17 sec)
another project with same hardware/software
strafor cnc (2 min 49 sec)
Jul 28, 2017, 02:12 AM
https://youtu.be/RqPWgSS-keQ
https://youtu.be/tlYftLG7bOg
Wow great job !!! Congratulations!
Too bad it was not for the mega arduino
I already have all the electronics arduino mega
But I do not know how to convert it
Great that you showed it to somebody will help it
In building own machine
Once again I congratulate and greet you
Jul 28, 2017, 06:47 PM
Nice work Varvar! I actually visited this website many times before, but like dj.pietrek I already had a Mega and the Ramps board....
Originally Posted by dpot
there is good reading her and runs on linux
http://www.theremino.com/en/downloads/automation
Actually, these days, the options are pretty much endless and the TheRemino option is a very good one too! I highly recommend it!
I have a theremino board laying around here and the only reason I did not used it is because my machine is a hybrid milling/hotwire, so, whenever I want to mill or cut foam I would have to rewire the drivers....With the arduino mega I just change the firmware accordingly (mill or hotwire) and keep the wiring as is....
I'm thinking about having a dedicated hotwire (a portable one that could be stored somewhere) and dedicated milling machine. The hotwire would definetely use TheRemino and the mill would use GRBL.
Jul 28, 2017, 06:52 PM
Originally Posted by Houghtelin
rasciodc - I don't have Microsoft Windows running on anything. Would you share the source code to the Hotwire Controller so I could take a peek and attempt to port it over to something I can use on Linux/Apple? Perhaps a Github link?
I purchased a new RAMPS setup just to give this a try and it all works perfect except the fact I don't have a Windows computer to run the darn controller on. I haven't tried to cut anything yet but that will be the next step. It seems I can get by without the controller (for now) with some G-code-fu. ^_^
Thank you for your work here!
Source Code added to attachments on first post, let me know it is on the format you need....
If it is too much trouble to adapt the code to run on Linux, I highly recommend using TheRemino. It is very cheap, constantly being updated and the CNC software seems to be very robust on any platform. Also, you can still use your RAMPS board with it...
Aug 07, 2017, 11:27 AM
how to use FoamXL 7.0
Hello budy, how are you,
Could you tell me how to use FoamXL 7.0?
Aug 07, 2017, 11:43 AM
Just got my Ramps and Arduino in the mail.
What length and dimension wire can you power, if there is only 12V available?
Edit: looked at the schematics for Jedicut, and they supplied 36V at the 11A input, so I guess it can handle it?
Lars
Aug 07, 2017, 07:18 PM
diagram of the shield with the nano
Hi Varvar, how are you?
Could you pass the wiring diagram of the shield with the nano?
Does this system work well with arduino-one as well?
Aug 08, 2017, 05:31 AM
Diagram of the shield with the nano
Aug 08, 2017, 08:54 AM
System works with arduino nano or uno
Aug 09, 2017, 07:06 PM
Would be to work with the uno
Hello Varvar good evening,
As the system works well with namo or uno then the best option
Would be to work with the uno, therefore the shield would perfectly
Without jumpers, am I right?
Aug 10, 2017, 01:38 PM
Unfortunately pinout is different and can not be done same, as for 3-axis CNC shield
Aug 10, 2017, 09:46 PM
Uno with the shield
Hello, Vavar, good night.
So can I use Uno with the shield that will work perfectly? Do you have the schematic for connection with a + shield?
Aug 10, 2017, 11:24 PM
Please take a look at post #24 - schematic is same.
Aug 11, 2017, 07:03 AM
Understand the scheme
Actually I'm not a technician, I do not understand the scheme! Could you send photos? Sorry lol
Aug 11, 2017, 08:18 AM
Sorry, I don't have photo for uno.
Discussion Simple but mighty DIY 4 axis CNC Foam Cutter - Theremino Controller (Not Arduino)! pieri70 CAD/CAM 141 Apr 10, 2019 10:43 AM
Build Log 4-axis Arduino based CNC hot wire foam cutter Søren Vedel CAD/CAM 196 Mar 24, 2018 08:21 AM
Discussion Software for 4 axis hot wire Jasongib Foamies (Scratchbuilt) 5 Jul 03, 2017 10:33 AM
Discussion Arduino and Ramps 1.4 for hot wire cutting jerome_ CAD/CAM 3 May 08, 2017 03:05 AM
Discussion FoamCasualty: 4 Axis CNC Hot Wire Cutter tvcasualty CAD/CAM 35 Jul 12, 2010 09:12 AM
