Jun 30, 2017, 12:02 AM
New Product
Matek BetaFlight F405-AIO Flight Controller, Built-in PDB, Dual Bec, OSD, 5 Uarts
Matek Systems is releasing a new version of the F405 Flight Controller
This has all the features of the Matek F405 flight controller and the Matek FC-HUB all together on one board
Matek Systems seems to have thought of everything with this one, they even include rubber anti-vibration dampners, a 35v 470UF Low ESR capacitor, and a flight controller plate for your stack.
This one should be in stock very very soon
You can check it out here
https://www.banggood.com/Matek-Systems-BetaFlight-F405-AIO-STM32F405-Flight-Controller-Built-in-PDB-5V2A-9V2A-Dual-BEC-p-1165338.html?rmmds=search
Description:
Description:
Description:
Description:
Description:
Description:
Specifications (User manual):
Brand name: Matek Systems
Item name: BetaFlight F405-AIO
PCB: 2.3MM, 6 layers & 2oz copper
Size: 36x51mm PCB with 30.5mm mounting holes & XT60 socket
Weight: 12g
FC Specifications:
MCU: 168MHz STM32F405
IMU: 32K ICM20602 accelerometer/gyro (SPI)
Max. 32K Gyro update & 16K PID Loop
OSD: BetaFlight OSD w/ AT7456E chip
Blackbox: MicroSD card slot (SD/SDHC)
VCP, UART1, UART2, UART3, UART4, UART5
Built in inverter for SBUS input (UART2-RX)
PPM/UART Shared: UART2-RX
SoftSerial on S5 & S6 optional
Smartaudio & Tramp VTX protocol supported
Spektrum BIND_PIN: RX4
WS2812 Led Strip : Yes
Beeper : Yes
RSSI: Yes
PDB Specifications:
Input: 9~27V (3~6S LiPo) w/TVS protection
PDB: 4x30A (Max.4x50A), 6 layers*2oz copper PCB
Dual BEC: 5V 2A & 9V 2A
LDO 3.3V: Max.300mA for Spektrum RX
Current Sensor 200A (Scale 165)
Battery Voltage Sensor: 1:10 (Scale 110)
Features:
2x LEDs for FC STATUS (Blue, Red)
6x PWM / DShot outputs without conflict
5x UARTs
1x Group of G/S1/S2/S3/S4 pads for 4in1 ESC Signal/GND
4x pairs of corner pads for ESC Signal/GND connections (DSHOT compatible)
1x pair I2C1 pads (for INAV firmware only)
1x Side-press button for BOOT(DFU) mode
package included:
1x Matek Systems BetaFlight F405-AIO
1x Rubycon ZLH 35V/470uF (Low ESR)
4x M3 Anti-vibration Standoffs
1x FR4 PCB Plate 36*36*1mm
New Product Matek F405-OSD BetaFlight STM32F405 Flight Controller /w 32khz Gyro ICM20602 nitbeat Multirotor Drone Electronics 26 May 17, 2018 01:44 PM
Discussion BF3.1.5 Omnibus F4 V2 Flight Controller STM32 F405 MCU Integrated OSD Built-in 5V BEC scousethief Banggood.com 10 Sep 13, 2017 06:21 PM
Discussion $34.99 - F4 FLAME Race Spec STM32F405 Flight Controller Built-in BETAFLIGHT OSD PDB BobFromMars Banggood.com 0 Jun 01, 2017 12:35 PM
New Product $25 Omnibus F4 AIO (FC + OSD) clone - Betaflight F4 Flight Controller STM32 F405 MCU lmpuIse Multirotor Drone Electronics 20 May 04, 2017 08:01 AM
Help! Mini-ACRO-F4-Betaflight-Flight-Controller-Built-in-PDB-5V1A-BEC-with-Micro-Buzzer aandz FPV Talk 4 Apr 02, 2017 08:28 AM
