Jun 29, 2017, 01:09 PM
parajared's Avatar
FAI ruling question: why is there a wing area limitation?
So I was reading the FAI sporting code for XC soaring records (SC4_Vol_CIAM_Records_17_V2) and noticed there was a limit on wing area. (Maximum surface area shall be 150 dm2).
Assuming the max AUW is 5kg why would they need a wing area restriction? Wouldn't building your glider too big be detrimental to the performance?
Jun 29, 2017, 09:08 PM
Sagitta Fanboy
There's a wing loading restriction in many of the F3 and F5 formats, and the combination of area & mass defines the range of permissible designs.
Having the wing area limit prevents people from building ultra-floaters as light-air only ships. It functionally limits the competitive designs to ones which are reasonably flyable in all flying conditions, not having pure high-wing and pure light air ships.
Jul 03, 2017, 01:07 AM
More or less you have a MAX of 2325sq in. to design a wing with. max 5Kg weight or 11.0lbs
Now plus or minus of your choice. Just make your own decisions. How do you make your Plane go 65-75mps ish. and keep it controllable while you are in a CAR under it while being bounced around in the sky etc....
Fun Concept Right!?!?!?
Jul 03, 2017, 11:51 AM
TrekBiker's Avatar
about the only reason I can think of to design/build a sailplane at the max square inches would be to set an altitude gained record. And it better be on a day with little to no wind. A giant sailplane with such light wing loading would be pretty much useless for all other XC soaring.
Jul 04, 2017, 11:56 AM
parajared's Avatar
Thanks fellas!
Jul 07, 2017, 02:18 AM
The FAI is a French organization may have even started before the Wright bros. When ballooning was popular.
The FAI limits on models were invented for a good reason a long time ago for model flying.
They were to define the difference between a model and a full size aeroplane.
As I remember all FAI events and records for C/L F/F and R/C still have these limits.
10cc engine 5Kg 150Dm and a wing loading that I cant recall.
Cheers jq
Jul 07, 2017, 08:24 AM
Sagitta Fanboy
Cheers jq
The FAI has always been an international organization, it was founded in 1905 due to a resolution passed by the Olympic Committee calling for an organization to regulate the sport of flying, and is headquartered in Switzerland. 8 countries national aero clubs were involved in the founding (some of which predate the Wright Brothers, but not by much. the oldest club involved dates to 1900)
Poll 2017 FAI Rules Proposals tedmonds Multi Task F3X 25 May 13, 2017 03:09 AM
Poll 2017 FAI Rules Proposals tedmonds Hand Launch 56 Mar 22, 2017 09:09 PM
Help! 80/20 Rule and Other Wing Questions skyfridge Modeling Science 316 Oct 26, 2016 09:24 PM
Discussion Why the FAA rule is invalid and why it is dangerous to register CosmicDog Multirotor Drone Talk 174 Feb 07, 2016 10:01 AM
FAI area rule again ptxman High Performance 14 Apr 29, 2005 02:00 AM
