Jeti Telemetry Sensor RPM Magnetic Hall Effect MRPM EX - RC Groups
Jeti has a new sensor available for JetiBox Profi and DC/DS radio systems. It's the MRPM HALL sensor and it's designed to provide RPM and power level data by using a Hall effect sensor along with a rare earth magnet.
Measure your RPM and Power Levels
Jeti has a new sensor available for JetiBox Profi and DC/DS radio systems. It's the MRPM HALL sensor and it's designed to provide RPM and power level data by using a Hall effect sensor along with a rare earth magnet. It can measure rotation speed and you can set up warnings that are triggered based on the data it provides. The information is transmitted in real time from the Jeti Duplex telemetry system.
The sensor has two way communication allowing it to transmit its data wirelessly to your transmitter, but it also can receive data from the receiver. You'll be able to see the data readout in real time on your DC/DS Jeti radio or on the JetiBox Profi. You can connect up to two hall sensors for two independent data sets, which is pretty dang cool.
Specifications
  • Dimensions: 25mm x 12.5mm x 5.5mm
  • Weight: 5g (with wires)
  • Accuracy: 10 rpm
  • Operation Temp: -10C to +85C
  • Supply Voltage: 3.5V to 8.4V
  • Power Consumption: 15mA
Learn more about the Jeti RPM Magnetic Hall Effect Sensor here
News KST Micro Cyclic Servo MS325 with Hall Effect Sensor ndfly700 Electric Heli Talk 18 Dec 30, 2017 09:51 AM
Discussion HTS-SS MRPM sensor with 2 magnet install on heli maingear?? menglovekai Hitec/Multiplex USA 0 Dec 27, 2011 03:03 AM
Discussion Using Different Hall Effect RPM Sensor with Recorder/Pro jrandle Eagle Tree Systems 2 Jun 25, 2011 02:04 AM
Discussion Hall effect RPM sensor kitedan Eagle Tree Systems 4 Jan 27, 2010 02:15 AM
