Matek Flight Controller F405-AIO - RC Groups
Jun 26, 2017, 08:08 AM
Dutch RC Reviewer
Dutch 79's Avatar
New Product
Matek is working on a new FC.
Tips, See bottom of this post.
After the successful Matek F405 with FCHUB-6S Matek is now working on a All In One FC.
Link to manual http://www.mateksys.com/?portfolio=f405-aio (Work in progress)
Product links https://www.banggood.com/Matek-Syste...8&rmmds=search status "In Stock"
Link to Matek FC group on Facebook https://www.facebook.com/groups/1882519175321708/
And When matek says AIO they mean AIO because it even comes with soft-mounts, Glass fiber protector and a Low ESR 35v 470uF Capacitor.
STM32F405, ICM20602, BFOSD, SD Card Slot, VCP+5x UARTs, PDB, Current Sensor 200A, BEC 5V/2A & 9V/2A
FC Specifications
MCU: 168MHz STM32F405
IMU: 32K ICM20602 accelerometer/gyro (SPI)
Max. 32K Gyro update & 16K PID Loop
OSD: BetaFlight OSD w/ AT7456E chip
Blackbox: MicroSD card slot (SD/SDHC)
VCP, UART1, UART2, UART3, UART4, UART5
Built in inverter for SBUS input (UART2-RX)
PPM/UART Shared: UART2-RX
SoftSerial on S5 & S6 optional
Smartaudio & Tramp VTX protocol supported
Spektrum BIND_PIN: RX4
WS2812 Led Strip : Yes
Beeper : Yes
RSSI: Yes
PDB Specifications
Input: 9~27V (3~6S LiPo) w/TVS protection
PDB: 4x30A (Max.4x50A), 6 layers*2oz copper PCB
Dual BEC: 5V 2A & 9V 2A (Room temperature 25C, 16V IN,
5V 2A cont. @ 5V pads nearby Cam tested with success)
LDO 3.3V: Max.300mA for Spektrum RX
Current Sensor 200A (Scale 165)
Battery Voltage Sensor: 1:10 (Scale 110)
2x LEDs for FC STATUS (Blue, Red)
6x PWM / DShot outputs without conflict
5x UARTs
1x Group of G/S1/S2/S3/S4 pads for 4in1 ESC Signal/GND
4x pairs of corner pads for ESC Signal/GND connections (DSHOT compatible)
1x pair I2C1 pads (for INAV firmware only)
1x Side-press button for BOOT(DFU) mode
36x51mm PCB with 30.5mm mounting holes & XT60 socket
12g
Accessories included
1x Rubycon ZLH 35V/470uF (Low ESR)
4x M3 Anti-vibration Standoffs
FR4 PCB Plate 36*36*1mm
Tips
1 Go to the Matek Website and see all the latest details http://www.mateksys.com/?portfolio=f405-aio
2 When you have weird behavior during take off, check if the quad movement is the same in Betaflight, forward is forward and right is right. If not check if you set board alignment to Yaw 270
3 DO NOT tension the ESC power cables, otherwise the soft mounting will be invalid.
4 Make a bench test w/o propeller & check the vibration in motors column of GUI.
5 Low ESR capacitor is must on the battery pads.
6 Arrow facing forward, Pls set the YAW Degrees “270”
7 The default setting for Dshot idle percentage was changed in the new BF version. Pls change the Motor idle throttle value back to 5~6.5, so as not to get the ESC desync.
8 If you use the SD BlackBox and get some issues. Pls type “set sdcard_dma = off” in CLI, Type”Save”. It is an open issue https://github.com/betaflight/betaflight/issues/2631
9 Enclosed rubber anti-vibration standoffs are necessary to avoid the vibration woes.
10 If Gyro 32kHz & PID loop 16kHz, Blackbox logging rate 1kHz Max.
SD Card, FAT32 C10, 1~32G, But max.4G space can be used in Blackbox.
11 Spektrum satellite BIND_PIN on RX4
Jun 26, 2017, 10:40 AM
**** me and I just purchased the HUB of the F405
Well I guess I need to build another drone then.
Jun 27, 2017, 08:06 AM
I like the layout of this, not many AIO fc with the xt60 mounted sideways. Good for frames like the chameleon.
Jun 27, 2017, 08:12 AM
Tr3TopFlyer
chyoung's Avatar
I think this FC with a whitenoise board to mount the unify and the X4R Rx would be a great combination on a Chameleon. Two board stack and you're done.
I wonder if the BEC is continuous 2a or just 2a burst like the OSD board?
Jun 28, 2017, 12:12 AM
Dutch RC Reviewer
Dutch 79's Avatar
I think it's 1.5A and 2A for 10 seconds
Jun 28, 2017, 01:26 AM
5V 2A cont. @ 5V pads nearby Cam.
5min testing.
Pass.
Jun 28, 2017, 02:55 AM
Dutch RC Reviewer
Dutch 79's Avatar
Nice, that's enough for a Runcam Split and led strip on 5v and VTX and rx on 9v
Jun 28, 2017, 03:14 AM
I am using the Split , 600mW VTX & one 8x2812LED strip on 5V rail.
Split recording with 0.55A load, my 5V VTX with 0.6A load.
Jun 28, 2017, 06:14 AM
Dutch RC Reviewer
Dutch 79's Avatar
That's quite a impressive load for the 5v only.
Very nice.
Jun 28, 2017, 07:45 AM
Tr3TopFlyer
chyoung's Avatar
5min testing.
Pass.
When are these shipping?
Jun 28, 2017, 07:49 AM
Dutch RC Reviewer
Dutch 79's Avatar
Around July 8th
Jun 28, 2017, 08:45 AM
Around July 8th
Do you know where I can pre-order one?
Jun 28, 2017, 09:03 AM
Dutch RC Reviewer
Dutch 79's Avatar
Not yet, I will update this when they are available for pre-order
Jun 28, 2017, 11:00 AM
Tr3TopFlyer
chyoung's Avatar
video noise?
would you expect the video noise levels on this board to be about the same as the F405 OSD, better or worse? I've found there is a little noise on the OSD board but a 1000uf cap seems to have fixed it. I'm wondering since the AIO ships with a cap that noise might have been more of a problem.
Jun 29, 2017, 02:22 AM
Frank.T's Avatar
I am in for one (or two, three,..)
Can't wait to order
Frank
New Product Matek F405-OSD BetaFlight STM32F405 Flight Controller /w 32khz Gyro ICM20602 nitbeat Multirotor Drone Electronics 23 Nov 11, 2017 03:19 AM
New Product $25 Omnibus F4 AIO (FC + OSD) clone - Betaflight F4 Flight Controller STM32 F405 MCU lmpuIse Multirotor Drone Electronics 20 May 04, 2017 09:01 AM
New Product Matek AIO Flight controller HUBF3-OSD8 (FC, OSD, PDB, Current sensor) blackchatte Multirotor Drone Talk 0 Feb 16, 2017 02:10 AM
