Jun 23, 2017, 07:21 PM
HGLRC TX20 20mm stackable 25-250mw
I was checking out hglrc's FB page to read up on the XJB f3 and f4 stacks, and I stumbled on this new 20mm vtx board. IVE BEEN DYING FOR SOMEONE TO FINALLY MAKE THIS!
Had to share.
#HGLRC XJB-TX20 Mini #FPV #Transmitter
Output power: 0/25mW/100mW/250mW switchable
BAT: 7-24V,BEC 5V-3A
170mA----250mW
120mA----100mW
80mA----25mW
Video system: NTSC/PAL
Antenna: IPEX
Frequency: 5.8GHz 9 bands 72 channels, with Raceband: 5325-5945 MHZ
Weight: 2.2g
#racingdrone #drone
https://m.banggood.com/20x20mm-XJB-T...p-1165158.html
Jul 05, 2017, 06:11 AM
MODDED MICRO MULTIS FPV
MONOAMORE's Avatar
I know. Looks great. I already have the FCB/esc stack and really want this to round out the set. Just can't find stock anywhere.
Jul 05, 2017, 07:18 AM
I was talking to some rep on fb, the communication was very uuhhh broken?
Was trying to get them to send me one for review.
Jul 05, 2017, 09:53 AM
z33
z33
Wow combo!
Jul 05, 2017, 10:32 AM
Banggood just listed it, should be available in a couple weeks
Aug 27, 2017, 08:29 AM
Does it really have a 3A/5V BEC output?
Aug 27, 2017, 08:40 AM
Will know in a few days for sure. Its coming in the mail.
Aug 28, 2017, 03:23 AM
I do not believe it has 3A / 5V BEC output. Observe the size of the inductor, obviously not more than 1A current.
Sep 11, 2017, 06:51 PM
Tx 20 black screen
I posted the same on another hglrc thread.....
Sorry if you read that..
Just finished my spintech frame setup..using the hglrc xjb/tx20 stack..
During the first couple of tests powered up, I was getting great video, but as I powered up to maiden, my screen is black, OSD shows up fine, AND there's a slight 1-2mm strip of video visible in my goggles...could this be a pal/ntsc setting? Or maybe a defect? Any ideas?
Sep 22, 2017, 04:02 AM
Got mine yesterday. Working good, although the BEC is only powering transmitter and 4 LEDs (WS2811b), and within 2 mins it gets so hot that it blisters the skin. Kinda worrysome.. not so bad in flight, but still not happy with the temperature.
Sep 22, 2017, 02:06 PM
Im going to try and hit it with batt voltage (4s). See if it runs cooler by using a bit of ohms law.
Sep 22, 2017, 03:23 PM
Mine is running off 3S, and with the BEC being a switching type, I doubt it will make a huge difference.
Sep 22, 2017, 06:23 PM
Well as it sits its not melting nylon standoff yet so its not that bad really
Sep 24, 2017, 09:48 PM
Flying tower is getting smaller and smaller, seriously affecting the heat, the high temperature is inevitable. Whether the high temperature is within acceptable limits.
Oct 28, 2017, 07:35 PM
Antenna disengaged
I was surprised to see that my antenna was no longer on my craft when I retrieved. Even more surprised to see the connector was no longer on the board! No clue where it went. Anybody else have problems with this? Wondering if it might be a fluke, or if that connector is really that flimsy. I'd expect the board attachment to be more robust than the antenna connector.
New Product Rush VTX 25/200/500mw $27 Stackable FarmerBoyFPV FPV Equipment 20 Feb 28, 2019 05:13 PM
New Product Diatone SP3 Stackable Switchable 25/200/600mW VTx /w OSD, Pigtail, & 5V BEC - $40 lmpuIse FPV Equipment 146 May 25, 2018 04:05 PM
Idea Idea: stackable physical form factor? ragamofyn Eagle Tree Systems 1 Jan 08, 2010 03:59 AM
Discussion Source for stackable pin headers in UK srnet DIY Electronics 4 Mar 15, 2009 05:58 AM
Stackable LiPo setup? new2heli Batteries and Chargers 4 Sep 27, 2003 11:19 PM
