differential mix
Hello guys
exist any option for configure the ailerons in differential mix for secure turn in big gliders ? I set this mix in my transmitter , but the AP not apply this mix. I need this response in aileron servos and possibility to change the % of mix:
thanks,. Regards |
impossible autolanding
Hi Zbig and guys.
I am trying to get and autolanding with the system. In April I share with you this video in which you could see that the plane touch down far 100 meters from the runway.
Following your instructions I change the parameters to include 40% correction of out of the route and I have been able to try again now. The problem was exactly the same or even worst. Please see the following video in the key moments to understand what is happening. FIRST TRIAL 00:40 seg. The plane go to the wrong direction, far from base and lower altitude. I recover the control to manual when the plane was 635m from base and only at 51 meters of altitude SECOND TRIAL 01:45 when I was at 278 mt and at 117 of altitude The plane turned and seems to go to the runway but it deviated to the right and due to the low altitude I recovered the control at 3:00. The course this time was a littler better but I seemed that the plane was in a parallel course of the real runaway. THIRD TRIAL 4:14 I switch to engage the Auto mode to the BASE (not autoland).I was almost in line with the base at only 40m of altitude. The system put the throttle to max (70%) to reach the minimum altitude and I recover the control. I seems that the course was fine for this mode. FOURTH TRIAL 10:16 Auto land mode changing the mode until 10:45 at more than 800 meters and 300 of altitude. The plane turn and take the right route but moving from right to left. AT 12:23 i dont understand why if I have set the altitude between 100 and 200 why the system is applying motor even with 240meters and the speed over 30km/h. You can see the plane loitering over the base without problem and with a radius between 120m and 35 At 14:31 I engaged the autoland and the plane went far away until 800 meters and 64 of altitude when I recover the control Here is the video to see those moments.
Is it the system working Right?Should I beat it? Burn it? |
Hi Zbig,
What is the settings to perform automatic landing in case of receiver failure ? I presume we first need to set a Runway but for all the auto-landing or return to runway modes an ILS layout must have been previously selected. In case of an receiver failure if the current layout is not with ILS does the AP select automatically the first layout with ILS to perform autolanding ? |
(or show at least screenshot with Autopilot, Runway and Service settings). Quote:
HD FPV with Pitlab and new functionality request
As a member of Pitlab’s fun club, I’m trying to create my FPV dream-system with it.
My goal is the most immersing and realistic FPV system for fixed wing. Recently tested Prosight as a HD video link with Pitlab AP on my MTD plane. What to say... it's a large step forward! There are two problems yet… 1. There is no OSD. Analog video link is working as telemetry channel only. So I have to use a Pitlab GS as a separate info screen during the flight. 2. 5.8Ghz HD video has limited range. 12db helix on the ground give me up to 6 km out distance. So, Zbig, my proposal for next software release is the following: 1. Include a second screen on "FPV tracker" with plane attitude, speed, height, direction to base and battery capacity indication as shown in attachment to be used in parallel to HD video link. 2. Include an option for Aux #4 and Aux #5 outputs to work as pan/tilt for onboard directional antenna. This will give the possibility to use 10db crosshair onboard and get a very solid video link on 5.8Ghz with up to 20db link budget. Let's make Pitlab an ultimate HD-ready FPV system! |
[URL="https://connexuav.zendesk.com/hc/en-us/articles/205152105-Ground-Unit-On-Screen-Display-OSD-"] Great post to bring up this issue. I am sure others have the same thoughts. Hector PS- Where did you get the antenna or components? |
My antenna tracker projectQuote:
progect 2 tracker antennaQuote:
Today in Poland we celebrate "Piotra i Pawła" / "Peter & Pavel" name day. Not sure Piotr (Pitlab) is celebrating it too but anyway... All The Best to Piotr (Pitlab)
PS: I sent you PM about our discussion. |
You in theory should give some airborne disturbance, I tried the ground but no significant disturbances, I use transmitter scherrer, I just have to try it as soon as I have some time. |
Thread Tools | |
Similar Threads | |||||
New Product | Buddy Flight™ in Pitlab&Zbig FPV System | Zbig | FPV Equipment | 15 | Oct 16, 2019 07:16 AM |
New Product | New version 2.50 official release of Pitlab & Zbig FPV System | Zbig | FPV Equipment | 3905 | Jun 21, 2017 07:18 AM |
New Product | New 2.4G & 5.8G Double Frequencies Wireless Video FPV System--Upgrade Version | bipowrc | FPV Talk | 7 | Dec 19, 2009 04:18 AM |
