Nov 11, 2021, 07:32 PM
I don't want to "Switch Now"
pmackenzie's Avatar
I have not built a pro, but if it is like other trays you sand the sides till it fits.
Nov 12, 2021, 04:03 AM
Originally Posted by Achi
Is there a trick to getting the servo tray into the pro fuselage? I can’t find any orientation in which it fits in.
Turn it 180 °. The orientation at your photo is wrong.
It is a very tight fit because of the rounded shape of the nose. Tilt the tray a little bit to one side and slide the first side in. Then push the other side in. It is tight!
Put the front wing screw in and push the latch of the servo tray against the screw. Glue it in place.
Nov 12, 2021, 04:57 AM
Rollo340's Avatar
Oh, please let me help you
First, flip the tray as you positioned it upside down.
If you look at the ballast slider, you might notice a little tooth.
Please srew in the front wing screw and move the tray until the tooth hits the screw. Mark the position of the tray, pull it out and cut of the tooth.
Sand both sides of the tray a little as well as the part of the fuseelage where you want to glue the tray. Due to the pretty sharp radius of the front part, the tray almost positions itself correctly. If you use ballast, please double check with the 100gr stick that it fits with the chosen position of the tray. Then use CA only (and accelerator if necessary) to glue it.
Cheers,
Rollo
Nov 12, 2021, 10:56 AM
Originally Posted by Rollo340
Oh, please pet me help you
Cheers,
Rollo
Thanks guys, and yes I realized I took the photo with the tray upside down. Makes sense to sand and fit it, but there are so many clever tricks I wasn't sure whether there was one for the tray as well!
Dec 01, 2021, 08:46 PM
Rollo340's Avatar
Hahaha
Dec 01, 2021, 09:43 PM
Where is the lift?
cptsnoopy's Avatar
Hahaha
Don’t have those issues here!
Charlie
Dec 02, 2021, 04:56 AM
Grind around with sandpaper and then press obliquely into fuse
Dec 07, 2021, 05:04 PM
CX5 just chillin (2 min 45 sec)
Dec 07, 2021, 05:27 PM
F3B and F3K
RetoF3X's Avatar
That looks relaxing!
I had the opposite experience yesterday, howling wind in Dallas.
It was still fun to fly my heavier CX5, taking some lift downwind, heading back upwind; catch and release of thermals.
The high flight stability of the CX5 surely helped.
Reto
Latest blog entry: thoughts on contest flying
Dec 07, 2021, 09:29 PM
Send some of that wind to me, Reto. The light stuff is always fun and challenging but so is the wind!
Dec 09, 2021, 06:05 PM
Rollo340's Avatar
Reminds me of charging my batteries and do some flying …too much kerosene flying recently .
But temperatures around the freezing point, wind and rain don’t really invite to fly DLG’s in Germany at the monent .
Can’t wait to attend the season opener in Carnation….hopefully
Dec 09, 2021, 06:37 PM
RCG Admin
Jason Cole's Avatar
I haven’t flown in weeks. Excited to get back out. Likely March for us to get back to good flying weather.
ThomasLee's Avatar
Looking forward to seeing you again bro!
Dec 10, 2021, 10:45 AM
Rollo340's Avatar
Same here…miss you guys a lot - f$#%k Covid
Dec 10, 2021, 10:51 AM
Will fly for Bourbon
DBSkyout's Avatar
That would be awesome to have you guys back! Miss my Bro's!!
Build Log Legacy Avaition 65" Turbo Duster zhavener Sport Planes 97 Oct 28, 2020 06:55 PM
Discussion G W Bush legacy seems to be unfolding in print, and its not kind AA5BY Life, The Universe, and Politics 80 Nov 19, 2015 03:08 AM
Discussion INSPIRE 1 PRO X5 and X5 RAW available here for Pre Order patrick21x Multirotor Drone Talk 0 Sep 10, 2015 09:45 PM
