This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Jun 18, 2017, 12:36 AM
old4570's Avatar
Battery Cradle ( 2 x 18650 ) 2s
Some time ago I said I was going to make a battery cradle for 2 x 18650 ( 2s ) to test 18650 for possible RC use ..
I made the cradle some time ago complete with a balance plug .
Sorry Guys ! I deserve a Tardy slip !!!!
I stuffed up ...
I forgot to do a spring bye pass !!! ( Such a dumb ass )
So there I was wondering why one spring looked like it had cooked ( because it had - cooked )
I had done a double bye pass on the other spring , but forgot all about the other ( dumb ) , I must be getting old or something .
Anyhow , I did a double bye pass on the front spring and VIOLA !! ( or is that Eureka )
Now that the batteries are not cooking a spring there is plenty of juice to feed the buggy .. ( such a )
So there you have it ... ( Lets get that link to the batteries )
http://www.ebay.com.au/itm/4x-Sony-U...8AAOSwLF1X-zzg
So the batteries are fine , just a dumb dumb playing with them ...
I am all out of these battery carriers , but I do have some on order ...
So I might do another with thicker wire ( bye pass )
1) So yeah , if you do this remember to bye pass the springs ( They dont like current )
2) The solid contacts should be fine ( much larger surface area ) if you really wanted you could drill and solder (?) but you take the risk of melting the plastic .
3) When soldering , I would recommend pliers to hold the contact points to act as a heatsink ( That melting plastic thing )
4) I added a 2s balance harness for the battery / voltage monitor / alarm , also if you want to charge the batteries in the cradle ( balance charge )
Help! Building a 18650 battery cradle. Does this look ok? JayJay68 Batteries and Chargers 9 May 10, 2017 11:11 AM
Question How do charge 2 x 18650 (series)? FyreSG Batteries and Chargers 17 Aug 27, 2014 08:18 PM
Discussion 2 X 18650 -->5V -Calling all battery Guru's- flyhigh1 Batteries and Chargers 2 Mar 13, 2013 03:44 AM
Discussion 2 x 2s in series OR 2 x 4s parallel...???? wagondriver42 Racing Boats - Electric 2 Feb 15, 2012 02:53 PM
Discussion Charging 2 x 18650 protected packs? Kerosene-AU Batteries and Chargers 4 Mar 30, 2011 05:31 PM
