This thread is privately moderated by bananen-k, who may elect to delete unwanted replies.
Jun 17, 2017, 06:32 PM
Designing a Me 163 fullfuselage
This is my Me 163 Design made out of depron, and styrodur.
This was my First atempt to cut the Wings in the surasto cnc wingcutter Maschine.
Using styrodur seems to be the better approach. Beside designing the Wings I desingned the fuselage
Jun 17, 2017, 06:49 PM
The Standard styrofoam is more bridle than the styrodur. Sanding styrodur is way more easier
Jun 18, 2017, 02:25 PM
I cut 30 sheets of 3 mm depron. The Komet is planned as a 760 mm wingspan Version. It shall be compareable with the Hacker Me-163. I'm also inspired by the causemann Design . But his plane is slightly bigger. (Around 1000mm)
Jun 18, 2017, 02:42 PM
I returned to the Wings. The wingspar is a 6mm carbon Tube. The hole was drilled with a 5mm Bit. The spar and the Wings are Glued together with epoxy. The cable channels are milled with a dremel. The servos are very small but unfortunately I picked high voltage Servos. Using the Standard 5V bec makes the servos shaky. So I used a "homebrew" Version of a bec. It is a voltage Regulator which can be adjusted to a desired voltage. I chose 7.5 Volt. It's all defined with the voltage devider on the pcb.
Jun 19, 2017, 12:20 AM
This is my cnc wingcutter I used for the Wings! The Software and Firmware is a modified surasto Version
Jun 20, 2017, 01:30 PM
The wingstips are sanded and the wing is glassed. I glassed only a Frame all the way arround. Afterwards the elevons are cut out. The hinges are made with glue (in Germany I can use uhu Por). The glue has to be attached, dried and than the elevons can be attached. Controlhorns with pushrods have to be glued on and screwed on.
New Product AF Model Me-163 Komet Red 950mm High Performance Rocket Fighter Drra Electric Warbirds 4 Mar 05, 2017 07:43 PM
Discussion Me-163 het magrinsi High Performance 15 Oct 10, 2016 03:08 PM
Question Me-163 Komet project. raggy2016 Slope 17 Aug 06, 2016 09:06 PM
