Aug 25, 2017, 08:04 PM
"consumerwil"
denisoni1's Avatar
I plan to use one as a last resort... I'm going to try to lower the mast first and add ballast
Originally Posted by liljimmy
Can you use an extended keel like a sail boat?
Jan 15, 2018, 10:25 PM
"consumerwil"
denisoni1's Avatar
360 Race Cam
I'm finally working on my video cam stuff and this is the 360 Mark Cam
360 Race Cam from Race Mark / Buoy - Its Alive!! (2 min 40 sec)
Nov 28, 2018, 11:30 AM
"consumerwil"
denisoni1's Avatar
Gonna try to add a GPS position hold...
Similar to this but trying to figure if I need a flight control board now. Was thinking of using 3 or 4 drives with rudders
Ardupilot 3.4 Loiter ( A.K.A. Position Hold ) (4 min 10 sec)
Nov 29, 2018, 05:17 AM
Looking at it, it seems that it really wants to naturally point downwind, so it always needs to reverse to compensate for drifting downwind. Perhaps with the high bits of superstructure more towards the stern? Or a vane? If forward drive and steering is more efficient, naturally pointing upwind might give longer run time for a given amount of battery power.
Thinking back to my early attempts at model boats, I had a couple of Airfix battleships, a Bismark and an Iron Duke. Both free running. Due to differences in superstructure layout, Bismark had a tendency to turn into the wind, Iron Duke tended to turn away from the wind.
Nov 29, 2018, 11:39 AM
"consumerwil"
denisoni1's Avatar
I was actually thinking a Vane potentiometer? ... maybe a sister mark to set distances at the start line? Also, since you'd need lots of battery power, was thinking of putting the battery in a PVC pipe and use as part of the anchoring?
Nov 30, 2018, 05:28 AM
Station keeping in still water is mostly a case of compensating for downwind drift. If the boat naturally points upwind, then controlled forward will result in the least power used to do the job. Unless a boat was designed to manoever backwards, manual reversing is a bit of a pig to do. An autonomous system doing corrections by reversing will probably be very busy, and thus power hungry.
Maybe a fixed vane, or, for sailing to station, a retractable one. Thnking about it, an arrangement used a lot on fishing boats to keep the bows to the wind and provide some side to side stability.
If the camera can pan through 360, it doesn't really matter which way the boat underneath it is pointing.
Jul 16, 2019, 10:11 AM
"consumerwil"
denisoni1's Avatar
version 3.0
I acquired a Proboat Alpha jet boat for cheap so thought I'd make good use of it...
FPV Pro Boat Alpha Jet boat with GoPro3 gimbal (1 min 43 sec)
Yippee! TINY FPV ZOOM 10X CAMERA VIDEO !!! Incredible FPV camera with zoom capability. JettPilot FPV Talk 24 Nov 02, 2016 11:07 AM
Discussion 10Xzoom fpv camera and 30X zoom fpv camera davidsz FPV Talk 83 Jul 30, 2016 03:30 PM
Discussion Walkera FPV iLook HD Camera. An action camera FPV ready tvdrone Multirotor Drone Talk 257 Feb 21, 2016 11:56 AM
Yippee! Camera for FPV - Here is a really good, high quality, and tiny camera for FPV flying JettPilot FPV Talk 526 May 24, 2015 12:53 PM
Question GoPro camera as a simple FPV for boats? RCBoater Dock Talk 10 Sep 11, 2014 02:04 PM
