FPV / Event Camera Boat - RC Groups
Jun 17, 2017, 04:52 PM
"consumerwil"
denisoni1's Avatar
Build Log
Hey there... Just starting this build:
FPV/Rescue Boat/Racing Event Camera Boat - Idea (1 min 25 sec)
Jun 17, 2017, 07:03 PM
Old Duffer
Garboard's Avatar
Interesting! Keep us posted.
Jul 26, 2017, 01:57 PM
"consumerwil"
denisoni1's Avatar
Adding FPV
I just ordered this FPV setup:
https://hobbyking.com/en_us/visionplus-fpv-goggles.html
https://hobbyking.com/en_us/quanum-e...8ghz-ntsc.html
Using it to position the camera for recording. Will use a servo to rotate the gimbal .... Now to figure out how to record...
Aug 03, 2017, 11:55 AM
Denison Converted my Southampton to use a GoPro camera, learned some lessons. first is that the weight needs to be close to deck level(boat tenderness affects the video), boat must be very handy in the positioning, the gimbal setup will help in the Shot area but will make the operation very busy. Also during operation the camera boat must be the one to clear traffic and not interfere with the others on the water. Also need to figure out the video editing program as there is a lot of extranous video in the making. figure the ratio of video to finish around 15%.
Aug 04, 2017, 09:52 AM
Big Boats Rule!
boater_dave's Avatar
The idea of a dedicated camera boat is interesting. Could you do it with two radios? The pilot would operate the boat, while the cameraman operates the camera functions. Both standing next to each other so the cameraman can direct the pilot where to head for the drama shots. That way the pilot can be focused on controlling the boat.
I've always thought this would make for a fun rc tank setup too. One driver, one gunner, two radios.
Dave
Aug 05, 2017, 08:52 AM
"consumerwil"
denisoni1's Avatar
Thanks for the comment. I plan to have enough ballast in the hull to keep it still. I had tinkered with possibly adding outriggers too. And agreed, the impact of the boat is to remain to the side or way in front. It will double as a mark-setter / rescue boat too.
Aug 05, 2017, 09:03 AM
"consumerwil"
denisoni1's Avatar
The more I dig in to this the more I think it should be a 2 person operation but I really want to keep it single and with 6 channels. I would need 2 for throttle & rudder; 1 to turn on cameras; 1 pan; 1 tilt; 1 lower and raise rescue arm.
I've ordered this FPV setup
Quanum ELITE QB58 TX CAMERA COMBO Micro Cam VTX 25mW 40CH 5.8GHz (NTSC)
Visionplus FPV Goggles W/ Integrated 5" TFT Monitor And 40 Channel Receiver
I was thinking the goggles would be on the transmitter so I can see the camera recording while watching the boat itself. I need to figure out the recording.
Dave
Aug 07, 2017, 12:54 PM
Big Boats Rule!
I was talking with a friend who bought a very expensive quad copter for use in commercial advertising and real-estate marketing and the like. His machine had a pan and tilt fpv system that also doubled as a pilot view, so with the push of a button the camera would center straight ahead so he could fly by video feed. But while the machine was following a pre-made waypoint flight path, he could pan the camera around. The entire time a high quality video feed was coming in to the screen on the controller. The video was being recorded on the ground and to an board memory card to be retrieved after landing. Now with multi channel fpv systems, you could split screen two feeds, one for the pilot, the other for the panning system. Save the feeds separately, or even just the pan feed, for video editing later.
With your layout for the controls mentioned, a typical 6 channel aircraft layout would work. Two double gimbal sticks, one for the boat, one for the camera. The landing gear switch (on/off) to engage the camera, the flap control (variable) for the arm.
Dave
Aug 07, 2017, 01:23 PM
"consumerwil"
denisoni1's Avatar
Thanks Dave, I'm going to keep this idea of yours in mind. I'm hoping I can get it done in time for the Cdn IOM Nationals in Alberta. Should be able to get some super cool footage.
Dave
Aug 07, 2017, 04:13 PM
It will need a 2 man crew, but it only needs one controller. The other crewman would be an observer to offer advice to keep the FPV boat out of trouble. Steering the boat and framing shots you lose awareness of things going on around you, an extra pair of eyes helps.
Aug 09, 2017, 03:14 PM
"consumerwil"
denisoni1's Avatar
Interesting to think of it being a 2 person crew.. I was actually thinking of using a way point gps for a set pattern. I'd have the vessel far enough from the racing and also hook up an override in case I need to reposition it.
Aug 12, 2017, 12:32 AM
"consumerwil"
denisoni1's Avatar
Some power...
Found some of these :P
2 would be too much eh? I'll just use the smaller one then lol...
Aug 19, 2017, 12:50 PM
"consumerwil"
denisoni1's Avatar
Update - running gear installed
Some video of my boat today...
FPV Event Recorder / Rescue Boat - Update pt2 (3 min 56 sec)
Aug 21, 2017, 01:31 PM
"consumerwil"
denisoni1's Avatar
Too top heavy :(
Bummer I went to float test the boat and #1 - Too top heavy. I guess the weight of the camera had leverage on the single hull; #2 - not enough balast, boat was too low after putting enough ballast in to try to support camera.
Next step now is lower the height of the camera and maybe get a carbon fiber tube.
Aug 25, 2017, 06:02 PM
20M northeast of Hell Mi
liljimmy's Avatar
Can you use an extended keel like a sail boat?
Latest blog entry: Blog
Yippee! TINY FPV ZOOM 10X CAMERA VIDEO !!! Incredible FPV camera with zoom capability. JettPilot FPV Talk 24 Nov 02, 2016 11:07 AM
Discussion 10Xzoom fpv camera and 30X zoom fpv camera davidsz FPV Talk 83 Jul 30, 2016 03:30 PM
Discussion Walkera FPV iLook HD Camera. An action camera FPV ready tvdrone Multirotor Drone Talk 257 Feb 21, 2016 10:56 AM
Yippee! Camera for FPV - Here is a really good, high quality, and tiny camera for FPV flying JettPilot FPV Talk 526 May 24, 2015 12:53 PM
Question GoPro camera as a simple FPV for boats? RCBoater Dock Talk 10 Sep 11, 2014 02:04 PM
