Portable Power Supply for camping, caravan, outdoor activities - RC Groups
This thread is privately moderated by bestpower4u, who may elect to delete unwanted replies.
Jun 14, 2017, 09:18 PM
400Wh Portable Power Supply, the best power generator when you camping, hiking, caravan travel, or any other outdoor activities.
PS5B 400W high capacity portable solar power generator AC power supply energy storage system with MPPT solar controller
Model No:PS5B-400Wh
Battery
Battery Capacity: 400Wh
Battery Type li-ion battery
Charge
Appro Charge Times/AC Wall Charger: 4 hours (120W)
DC Car Charger: 8.5 hours (48W)
Solar Charger: 4 hours (120W)
AC Output
Rate Output Power:300W
Peak Output:600W
Output Voltage:100V/110V/120Vac
220V/230V/240Vac
Output Frequency:50/60Hz0.5Hz
Overload Ability:120%<load<130% @10min
130%<load<150% @10s
DC Output
4 x USB Port 25V2.1A &25V1A
1 x 12V Car Port 120W
2 x DC 6mm Port 212V3A
General
Working Condition:Relative Humidity: 5%-90%
Discharge Temperature: -10~60℃
Charge Temperature: 0-45℃
Product Dimension:230*140*235mm
Net Weight:5.6Kgs
Gross Weight:6.2Kgs
Widely used for indoor or outdoor such as family, office, travel, camping etc.
Easily powered from AC wall outlet, DC car charger or solar charger.
LCD battery display indicate the remaining capacity, charge, discharge and failure status. once it is fully charged,
All battery segments will be lit and remain solid. it will stop charging battery by the built in advanced system control circuit module.
Built in lithium ion battery cell, more weight lighter, long lifespan, safer, environmental-friendly and portable than other competitor's lead-acid big heavy one.
What you can get portable power storage, AC wall charger, Car charging cable, Solar charging cable, Jump starter alligator clip cable, User manual, Warranty card.
New Product Need an ultra-portable 60W power supply? Look no further! Julez Batteries and Chargers 7 Jan 06, 2017 02:38 AM
Discussion Portable 12/24 Volt 800/1600 Watt Power Supply Setup 376782 Batteries and Chargers 7 Sep 10, 2012 12:05 PM
Discussion What Portable Power Supply should I get danik Micro Helis 15 Jan 25, 2008 01:04 AM
nifty portable power supply PunkerTFC Batteries and Chargers 3 Jul 23, 2003 01:44 AM
