Temperature difference between internal sensor and plugged in sensor - RC Groups
Jun 14, 2017, 03:24 AM
nonoze's Avatar
Hi,
I've noticed a quiet big difference between the temperatures given by built-in sensor, and plugged-in sensor: 6C, even indoor, when i've just turned-on my model, TC should be the same.
It seems that built-in Temp is wrong, too low by 6C, how to solve it?
The Firmware i'm using is the April release.
Thanks!
Jun 14, 2017, 09:26 AM
JohnET's Avatar
Hello,
The internal temp sensor being enclosed inside the case can have a different reading that the external sensor. If you would like to send the system to us to test to see if it is within spec, please open a support ticket on our website.
Regards, John
Jun 14, 2017, 09:42 AM
nonoze's Avatar
Originally Posted by JohnET
Hello,
Regards, John
Thanks John, no, it's not a big deal, it's just disturbing to see 2 different temperatures side by side on my OSD knowing that they should be similar.
A good idea might be the possibility to adjust the temp like you did with the air-speed.
Help! Sensor rpm y sensor temperature mz 24 in trex 700 nitro imagine 50 Graupner OPENHOBBY 0 Jun 02, 2017 03:32 PM
Discussion Difference in flight characteristics between different frame styles/sizes Prowlr FPV Racing 2 Dec 29, 2016 09:55 AM
Discussion Temperature Sensor w/ Plug Nitro_Nancy HobbyPartz.com 0 Jan 15, 2016 06:11 PM
Discussion Difference between Tiny OSD III w/ 60a Current Sensor vs 80a current sensor? sonicweapon FPV Equipment 1 Nov 02, 2013 06:22 PM
Discussion The differences between different verions of brushless rpm sensor? herbalist Eagle Tree Systems 3 Jan 12, 2011 12:55 AM
