This thread is privately moderated by scousethief, who may elect to delete unwanted replies.
Jun 13, 2017, 06:43 AM
Quad Erat Demonstrandum
scousethief's Avatar
RunCam Split Micro HD FPV Camera with WiFi Module - ORANGE/BLACK
Gearbest, Orange $74.99
Banggood, Orange US$74.99
Banggood, Black US$74.99
Available from both popular vendors the Runcam Split aims to form a bridge between those who require an FPV camera and those who require a higher detailed video output and who are limited on space. The Split will perform the actions of both popular types of camera but without adding the extra weight or induced lag that occurs when trying to use an action camera as the main view camera, hopefully . The spec's listed below state [email protected] for recording is an option but doesnt list the FPV resolution , trying to cram anything like 1080p across the 5.8ghz we use will result in frame skip/drop or worse lag so hopefully the Split reduces the resolution before sending the video to the transmitter.
English Manual
Description :
Brand Name : Runcam
Item Name : Split RunCam 3
FOV Angle of Field FPV FOV 130 / Recording FOV 165
Video Resolution [email protected] / [email protected] / [email protected]
Video Files MOV
Image Resolution 2 Megapixels
TV Output NTSC / PAL Switchable
Real-Time Audio Output Yes
Interface Micro USB / UART
Max Micro SD Card Supported 64G(need Class 6 or above, recommend Class 10/UHS-I/UHS-II)
WiFi Module Support (Removable)
Dimensions PCB 36*38mm / Lens Module 22*20mm
Power Input DC 5V
Working Current 650 mAh
Weight 21g
Features :
HD recording, same effect as Runcam 3
Supper WDR FPV image with low latancy
Recording and FPV can do at the same time
26g super light
Camera + Board split, main board and FC can be installed on frame kit, camera is same as mini Swift.
Lens is removable
WiFi module is optional, support APP setting and previewing on mobile.
Package Included :
1 x Runcam Split Camera
1 x Mounting Bracket Pack
1 x Cable Pack
New Product Runcam Split / V2 - FPV + HD Camera nitbeat Aerial Photography 2324 Jun 14, 2019 06:30 PM
Video RunCam Split FPV + HD Camera AIO Review marblekit FPV Equipment 7 Nov 20, 2017 10:07 AM
New Product Runcam Split - Low Latency FPV Camera with Runcam 3 Quality Recording Nickz88 FPV Equipment 7 Jul 18, 2017 06:58 AM
