Giovanni,
Ho visto che hai cercato di mandarmi un messaggio. Purtroppo devo fare un po’ di manutenzione nel mio inbox visto che è pieno di nuovo. Comunque sembra que Hansen ti ha mandato la piantina che misi assieme. Se necessario, mi puoi sempre mandare email, invece di un messaggio, via il sistema qui di RCG. Saluti, Davide. |
Triton kit
Is anyone watching this?
https://www.ebay.com/itm/DUMAS-MODEL...197a%7Ciid%3A1 I am so tempted to collect another one. |
Then I saw the one on eBay and is sort of tempted to get it just to build it as glow power. Decisions, decisions....... I wound up buying this instead. https://www.ebay.com/itm/PILOT-Crown...rdt=true&rt=nc |
Nice find!
I know I have seen this model in a catalog from back in the classic pattern hey days. But never seen it assemebeled or flown. That kit (ARF), Pilot "Crown-404" has some traces of a Simla plane (by Ed Kazmirski) I think. Maybe the designer at Pilot factory got some inspiration from such source - who knows. We had a major Pilot models importer in our country in 1970th and sure enough in his 1975 cataloge he had the pilot Crown-404 listed, it was also a smaller Crown-202. http://www.tmfk.org/antikrundan/Valt...ansson1975.pdf (page 7 in this Swedish PDF cataloge , I Think I scanned it myself for that website webmaster). The Crown 404 has a wingspan of 135 cm (53 inch) and was for 5-6.5 cc 2-stroke. The little sister plane had a wingspan of 118 cm (46.5 inch) and was for 2.5-4 cc engine). /Bo |
Maybe the designer at Pilot factory got some inspiration from such source - who knows.<< A lot of the Japanese designs supposedly took inspiration from the Taurus and Simla. I had another pattern plane back in the days that was called a "Taurus". It came in a plain card box box and looked nothing liked a Taurus. It had a fiberglass fuselage that is pretty generic. The nose tapered into the spinner. The Taurus nose never tapered to match the spinner. The vertical tail fin was more upright like the Kwik Fli. The wing span was similar as it had a 70" wing span. Regardless it was one of the better flying pattern plane I had. >>We had a major Pilot models importer in our country in 1970th and sure enough in his 1975 cataloge he had the pilot Crown-404 listed, it was also a smaller Crown-202. http://www.tmfk.org/antikrundan/Valt...ansson1975.pdf (page 7 in this Swedish PDF cataloge , I Think I scanned it myself for that website webmaster).<< Man that sure brought back memories. The MK Tiger was one of my very first successful RC airplane. I had a Graupner Topsy before that but it did not fly because of the Galloping Ghost radio that I bought used and not working well. The Futaba radio in the scan was one that we made fun of all the time at the flying field. Anyone showing up with one of those radio will crash within 3 flights. Sure enough and that's why we all stayed away from Futaba. I still have a bad memory of the Futaba brand. ![]() I still have parts from a Kyosho RC dune buggy that was at the bottom of the catalog. Not enough to make a complete buggy unless I manufacture the parts myself. ![]() ![]() ![]() Oh and those IM hardware. Especially nose gear with the double struts. >>The Crown 404 has a wingspan of 135 cm (53 inch) and was for 5-6.5 cc 2-stroke. The little sister plane had a wingspan of 118 cm (46.5 inch) and was for 2.5-4 cc engine).<< I hope it is a fun built. It is suppose to be missing some parts like the canopy and some plywood pieces. I will have to find some replacements. I am always on the look out for old obscure Japanese kits. I missed out one a Debonair Panther before. |
https://parkflyerplastics.com/cart/i...index&cPath=46 Maybe a Goldberg Skylark 56 canopy they have could fit? It looks rather similar in shape. /Bo |
Finally, period correct......
.....my Triton was built back in 2016 as an electric. Then I found a source for methanol fuel and has been flying glow. I have been itching to convert the Triton back to wet fuel power. I started the process recently. Then I found out all my engines are too long for the nose. I finally pulled out an OS gold head FGP. I bought it used on eBay. Then I slowly collected brand new parts to rebuild the engine. It is now basically a brand new engine. It has brand new cylinder sleeve, piston, piston ring, crank shaft and bearings. Broke it in for 1/2 a tank on the bench and put it in the plane.
Flew it today and it sure brought back some memories. The engine is the star of the day. Very smooth running and very friendly. The plane came in at 6 pound 7 ounces and the engine hauled it around very nicely. The engine is still breaking in. By the fourth flight I was doing some very large loops. One of the minor issue that is noticeable is that when the power goes up the tail starts to wag. It could be the turbulence but I believe it has to do with the speed of these old classics. They are not meant to fly fast. I am going to try a 12 X 6 next time I take it out. Right now I am using an 11 X 8. Need to get a spinner first. I don't have a 2" Tru Turn that will fit an APC 12 X 6. |
Fantastic!
I have one of those engines NIB, need to build something for it one of these days |
Hansen,
That is indeed period-perfect! My mentor had a Triton with a Goldhead (not the same color scheme, but still ... ) and of course I yearned for one of my own. That could still happen! ![]() I agree, those old birds were meant for a lower speed range ... also, the large bubble canopy does funny stuff to the airflow, which is why a lot of them ended up with a dorsal ridge like on the Triton, whether they were designed with it or not. So the 12" x 6" prop is definitely a better choice if you have enough ground clearance, so you can put the extra power to work for static thrust and vertical climb performance rather than trying to push the airplane faster than it wants to go. I recently acquired an old Super Kaos, which I've now flown and am fixing up bit by bit. I won't be adding a dorsal ridge but I do intend to increase the ground clearance for a 12" prop. Will post pictures when I have something worthwhile to report ... meanwhile, congratulations on a beautiful vintage project! Cheers, Duane |
>>I agree, those old birds were meant for a lower speed range ... also, the large bubble canopy does funny stuff to the airflow, which is why a lot of them ended up with a dorsal ridge like on the Triton, whether they were designed with it or not.<<
I am not sure if the dorsal ridge does anything. Most other designs go with a ventral fin. Those seem to work better to stabilize the tail. I am itching to do an experiment to a Kwik fli. That is the tail wagging machine. If I can change the characteristic by a ventral fin that would shed some answers. >>So the 12" x 6" prop is definitely a better choice if you have enough ground clearance, so you can put the extra power to work for static thrust and vertical climb performance rather than trying to push the airplane faster than it wants to go.<< I have enough ground clearance to go another 1/2". I actually had to make a shorter landing gear strut set when I converted back from electric. >>I recently acquired an old Super Kaos, which I've now flown and am fixing up bit by bit. I won't be adding a dorsal ridge but I do intend to increase the ground clearance for a 12" prop. Will post pictures when I have something worthwhile to report ... meanwhile, congratulations on a beautiful vintage project!<< Thank you. Making different landing gear struts is pretty easy for me. I had these K & S wire bender and coil winder for over 30 years. Never liked them when they were new and I was inexperienced. However as time goes by and I get more experience using them they really do work well. |
Thread Tools | |
Similar Threads | |||||
Build Log | Building the Dumas Jim Kirkland Triton kit | SeismicCWave | Classic Pattern Flying | 77 | Jul 04, 2016 05:10 PM |
Discussion | Old Triton Jr. GPMM3152 can't find battery | RobbieHamilt | Batteries and Chargers | 1 | Dec 07, 2015 12:59 PM |
Question | Triton Plans from Dumas Kit | RTLIKES RC | Classic Pattern Flying | 16 | Jul 08, 2015 10:27 AM |
Discussion | Dumas Triton | vintage pattern | Classic Pattern Flying | 17 | Mar 28, 2015 06:06 AM |
Help! | Dumas Triton Plans | Skyhawkjock | Classic Pattern Flying | 2 | Jan 11, 2013 05:34 PM |
