Jun 12, 2017, 10:53 AM
Cantaloupeman's Avatar
Airtronics sd5g losing signal
So I've posted a few times on this, but my airtronics sd5g loses signal quite often. It's usually in little bursts and most of the time it seems to be in the same spot when I'm flying. I've had this issue since I got the radio and it happens on multiple planes and both receivers I own. Could this be an issue with a loose solder joint? If not is there anything I can do to diagnose it?
Jun 12, 2017, 01:53 PM
Cantaloupeman,
I would perform a range check with the Rx removed from the plane. Focus on the blue Rx LED. If the blue LED does not stay solid but blinks or goes off completely you might be flying in an overcrowded 2.4GHz environment. The blue Rx LED monitors "hits" on the same frequency. Unfortunately, the manual does not mention it.
Jun 18, 2017, 10:00 AM
So would I just turn on the TX and leave it somewhere and carry the RX and batt with me until I'm far enough away?
Oct 15, 2017, 06:00 PM
Hi. need some help with Airtronics. Would you both take a look at this tread please? https://www.rcgroups.com/forums/show...m#post38454334 I am loosing faith on Airtronics
Discussion Radio losing signal batata003 Radios 30 Nov 21, 2016 08:10 PM
Discussion Airtronics sd5g Cantaloupeman Electric Plane Talk 0 Nov 06, 2016 08:09 AM
Discussion Help! FlySky ia6 receiver loses signal with small impacts Little_Horn Radios 4 Sep 10, 2016 09:00 AM
Help! I am losing a part of my signal... jbalint1122 Multirotor Drone Electronics 8 Sep 04, 2016 11:55 PM
Discussion DX7 loses signal,42'' Slick dead!Tx powers up,no signal? evalith8 3D Flying 4 Jan 27, 2011 02:27 PM
